Silicone RTV on Trans Pan Gasket - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 07-09-2010, 10:06 AM Thread Starter
Hello, I had my transmission serviced (E4OD) and noticed that when the pan was reinstalled, a lot of silicone sealant was placed between the pan and the rubber gasket. Good bit squeezing out. Is this a bad thing? Never seen sealant used on an E4OD or 4R100. Thanks!
- 1996 F-350 XLT 2WD CC DRW, 7.3l PSD / E4OD, 120K miles
Previous Trucks:
- 1986 F-250 RC/LB XL 4x4 6.9l (Sold)
- 2004 F350 CC/LB DRW KR 4x4 6.0l (Totaled)
- 2000 F250 SC/SB XLT 4x4 7.3l (Sold)
- 2006 F250 CC/SB Lariat 4x4 6.0l (Stolen)
- 2003 F250 CC/SB XLT 4x4 6.0l (Sold)
- 1969 F100 RC/LB XL 4x4 360ci (Sold)
troy520 is offline
post #2 of 6 (permalink) Old 07-09-2010, 10:45 AM
Just had my rebuilt a couple thousand miles ago. New seal leaked on mine so they put that stuff on mine as well----no leaks and no problems so far.
'96 F-250 178,500
'95 EB 193,000
'05 Excursion 4x4 V10 78,000
msuforeman is offline
post #3 of 6 (permalink) Old 07-09-2010, 02:00 PM
91diesel's Avatar
I would use permatex ultra black rtv or the permatex right stuff and/or permatex great stuff on EVERY gasket if I could..i hate cork gaskets..especially pan gaskets, which powerstrokes/idi's dont use(or shouldnt).
Seriously, they are all great sealants, and it is normal that it is squished out, not going to hurt anything. Its only bad if its leaking.
91diesel is offline
post #4 of 6 (permalink) Old 07-09-2010, 02:04 PM
Feedback Score: 2 reviews
You don't need any sealant on the pan gasket, i have reused the same gasket 4 times. You will have some clean up on the next service, the filter will keep out any silicone that comes off.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #5 of 6 (permalink) Old 07-09-2010, 02:08 PM
91diesel's Avatar
Yeah, I wouldnt use sealant and a gasket.
Use one or the other is safe to say. I guess its preference on gaskets or sealant for some things
All this ranting going on, I dont think you need to do anything about it, troy
anthony
91diesel is offline
post #6 of 6 (permalink) Old 07-09-2010, 10:29 PM Thread Starter
Thanks huge for the replies! I'll just drive it and not worry about silicone getting where it shouldn't. Thanks again!
Previous Trucks:
troy520 is offline
