Slave Cylinder
I got my new South Bend Clutch on, as well as the SM flywheel. I'm still having a problem though. When I press the clutch pedal in, it throws the slave cylinder off of the clutch fork. The rod from the slave cylinder seems to jump out of place. The clutch pedal stays pressed in. When this happens, it throws the clutch fork off of the throw out bearing. I pulled back the rubber boot from the slave cylinder, and there's some plastic missing on it. It looks like I must have broken it during the clutch job. Where should I go from here?
Thanks for the help!
