When I start my truck, it spins over fast at first then slows down. It got so bad last week it would hardly roll over. My batteries are missmatched and old, so I replaced both of them with 850 CCA. I thought I had it fixed, but I noticed it again this morning. The truck has 165000 miles on it and runs very well. I'm not sure what to check next. Any ideas? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
John
1996 F-250, Ext Cab, 4wd, 5spd, Long bed, Gutted EBPV, Shimmed FPR, SCMT, LUK SMFW, 200,000 and counting.
Yes, starter. Weak batteries and/or lots of cranking will wear it out. I was going through one a year when it got cold. Now with the GP's disconnected, and a shot of ether, I'm off, and the starter made it through the winter [img]/ubbthreads/images/graemlins/cool.gif[/img].
96 F-350 4x4 CC LB, International block and heads from Mcandless IH in Denver, <span style="color: red">Baby Swamps </span>, Luk Cerametallic Clutch, 5" straight exhaust,5 speed ZF, 4.10's, Evolution programmer, Banks brake, non-EBPV IH turbopedestal, AFE Magnum force, CA reg. kit, 12,000 lb. Milemarker on reciever mount, 215amp ambulance alt., 33" muds on factory aluminum, Class 5 bumper hitch, hidden gooseneck, pillar gauges, fosgate amp, 12" sub.
Colorado National Gaurd.
"Firearms stand next in importance to the constitution itself. They are the American people's liberty, teeth and keystone under independece. When Firearms go, all go's. We need them every hour!"
President GEORGE WASHINGTON
I know NAPA couldn't get me any parts, didn't check w/ our local rebuild shop, but they could probably do it. You can replace it with a SD gear reduction starter or just another one like you have. I put a reman from NAPA on mine. Cranks faster than it ever has. I would check its current draw or have it tested first though. My reman was 230 thats too much to just replace.
Sold, back when the snow was on...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
I pulled mine and took it to AutoZone. They put it on their tester and tested it for free. Most auto parts stores have the capability of testing your starter. At least you would know if it is good or bad. [img]/ubbthreads/images/graemlins/smile.gif[/img]
02 F250, 4X4, 4R100, 3.73, Amsoil Air Filter, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug and Intercooler boots, 6.0 Transmission Cooler.
