Slow start after setting - Diesel Forum - TheDieselStop.com
Old 03-03-2005, 02:50 PM   #1 (permalink)
jricherson's Avatar
My Photos: (12)
I drive my truck mainly on the weekends and occasionally during the week. I have a company car and no use putting miles on mine. But after it sets for a week it cranks for about 4-5 seconds before starting, normally it only takes about 1-2 seconds.
I checked the HPOP after setting and the oil is within 1/4" from the top.
Any other ideas?
Not a major issue as it always starts but wondering if this is normal.
1996 F-250, 4x4, SWB, 7.3L, Supercab, Tymar, AFE Big Bore 4" exhaust with 3"-4" DP, Baby Swamps 150cc, TS performance 6 pos chip, Terminator T500 HPOP, HPX Crossover, EBPV gutted and shimmed FPR, Carr Hoop Steps, Cab Lights, Limited Slip 4.10 rear end.
http://rides.webshots.com/album/1774...av?vhost=rides
jricherson is offline
Old 03-03-2005, 03:42 PM   #2 (permalink)
Re: Slow start after setting
Check your glow plugs and glow plug relay to see if they are working properly. If they are, have your batteries and starter motor tested at a parts store. They will usually do that for free. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
02 F250, 4X4, 4R100, 3.73, Amsoil Air Filter, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug and Intercooler boots, 6.0 Transmission Cooler.
Griz is offline
Old 03-04-2005, 09:31 AM   #3 (permalink)
jricherson's Avatar
My Photos: (12)
It even takes a few cranks when I plug it in for the week. It could be the starter, I cleaned the connections and terminals, etc. but no difference.
Old 03-04-2005, 10:00 AM   #4 (permalink)
If you haven't had your batteries tested, I would do that. And make sure you are using the right size battery for the PSD. I 'believe' you need something like 850 CCA or above for these rigs. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Griz is offline
Old 03-04-2005, 10:36 AM   #5 (permalink)
jricherson's Avatar
My Photos: (12)
The batteries are 5 month old and are 1000 CA and 850 CCA.
The engine turns over fast, about the same as a friends 97'
It just takes more cranks after setting than when started within a day or so.
