So how cold will a psd start w/o being plugged in - Diesel Forum - TheDieselStop.com
Old 01-22-2013, 05:42 PM   #1 (permalink)
Stan96's Avatar
There sayin this is the coldest weather in two years, 8 degree's here this am, not too bad, just wondering, what's the coldest you've ever started without being plugged in? I've done 1 or 2 degrees a couple years ago, but it sounded like the engine was coming to an end.
1996 F-350 XLT 4x4, e4od, stock, Elect-rustproofing
2004, @32k mi. glowplugs, tires, drag-link
2010, @76k mi. Ball joints, u-joints, rotors
2011, @86k mi. glowplugs, drag-link, trany fluid
2012, @94k mi. Bilsteins, stainless brakelines, fuelbowl, lift pump, waterpump, steering lines, coolant filter
2012, @98k mi. Starter, positive cable, batteries
Stan96 is offline   Reply With Quote
Old 01-22-2013, 06:40 PM   #2 (permalink)
It is around 25 degrees here and the truck has been sitting for 2 weeks, it started up on second try and ran just fine.
The truck hasnt been plugged in at all.
1995 PSD F-350 4X4
97 motor installed.
DaveH. is offline   Reply With Quote
Old 01-22-2013, 07:13 PM   #3 (permalink)
bugman's Avatar
My Photos: (12)
I have started mine on glow plugs alone at a -40 here in Colorado. I will quite often start it in the minus temperatures after letting it sit for a couple of weeks and actually tomorrow morning I'll fire it up after letting it sit for 3 weeks and we will be below 0 when I do it.
bugman is online now   Reply With Quote
Old 01-22-2013, 07:50 PM   #4 (permalink)
Stan96's Avatar
yea, -40 is pretty cold, i was readin about batteries, somewhere i read that a 100% charged battery will freeze around -77 and a 75% charged battery will freeze at -35 At 50%, 10F. At 25%, 5F. At 0% (totally discharged), 20F.
not sure how true tho. at any rate, i'd be happy with starting at -5 or 10 around here..
Old 01-22-2013, 08:15 PM   #5 (permalink)
Guess I baby mine too much. lol. I plug it in any time its going under 30 deg. I have it on a timer so it turns on an hour before I leave in the morning. I'd rather spend a few cents on electricity than wear out a $250 starter motor. I did forget to plug it in one night, temp at 20 degs and it started on second preheat. Once started int he morning it can sit all day and start right up without any preheat 10 hours later. Guess the truck is like its owner, likes a little help getting going in the morning but then good for the rest of the day. lol.
1995 Ford F-350 crewcab PSD running on B100
frugalyankee is offline   Reply With Quote
Old 01-22-2013, 08:26 PM   #6 (permalink)
PSDan000's Avatar
My Photos: (11)
Send a message via AIM to PSDan000
for me it depends how long it sits. typically i can let it sit 12 hrs in single digit temps and get it started. 24 hours in the same kind of temps and i start having issues. if its under 20* i will typically leave it plugged in if its going to sit for 12 or more hours
-Dan
1997 F-350 PSD, Cali Truck, 165k, 4x4, Reg Cab, LB, 4.10's, Auto, Sandpiper Diesel Performance 4" Exhaust, DIY Open Intake, Autometer Gauges, TS 6 pos Chip...more to come.
#24
PSDan000 is offline   Reply With Quote
Old 01-22-2013, 10:02 PM   #7 (permalink)
I started mine this morning it was about 2 deg F. With 5w-40 oil and a SD starter it starts perfect, first time without being plugged in with no chugging or anything.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters. SD starter. Dieselsite T-stat. DP 80hp tuned PCM.
'04 F550XL reg. cab. ZF-6 speed. EGR delete. Coolant filter. Cat EC-1 coolant. LF777 bypass oil filter. Blue-spring fuel pressure regulator. ScanGauge II. Glowshift fuel pressure gauge.
sdan27 is offline   Reply With Quote
Old 01-23-2013, 09:03 AM   #8 (permalink)
Mine started with no problems a couple winters ago at -21°.
Snowtow is offline   Reply With Quote
Old 01-23-2013, 04:03 PM   #9 (permalink)
Mine will start unplugged down to about 15 it's a really hard/smokey start though so I plug it in below 30
95 7.3, 5spd Manual (197k)
4x4, Cherry Red, Ex Cab long box
Dual 16gal tanks
3'' turbo back strait pipe
2.8'' leveling kit
28.5 Toyo MT
delta7503 is offline   Reply With Quote
