Some direction on the old crack alot before start problem? - Diesel Forum - TheDieselStop.com
Old 03-02-2007, 10:43 PM   #1 (permalink)
Supercab79's Avatar
I'm having to do something that I was hoping wouldn't come for a long time. But you can't stop time or rust. I'm putting up my 93 and just put a down payment on a 97 350 PSD with 95000 miles auto XLT 4x4 the truck is very clean and the guy selling it just put in a new starter and had 8 new glow plugs and both wiring harnesses put in a the Ford dealer and a new GPR. The trucks Wait to start light and volt gauge show a draw on the plugs and the starter turns over quickly but it takes about 7 or 8 seconds or revolutions to get it started but after it starts theres no smoke or sputtering it purrs right along it's just the inital start up that's a bit long. One other factor is not been that cold the last 2 times I started it. It's been in the high 30's low 40's.
Thanks Marc
06 Dodge 3500 Laramie 4X4 Megacab Short Bed 5.9CTD
97 F-250 XLT 4X4 C/C Short Bed PSD, D60 Front Axle Conversion Tymar Open Air Intake, Full 4" Exhaust, DP 3 Pos Chip, Banks Billet Converter, ISSPRO Triple set, Banks Techi Cooler
87 F-350 XL 4X4 Stakebody 6.9 5 Speed (22 Years) OLD ENOUGH TO SMOKE
77 F-250 Custom 4X4 Crew Cab Short Bed 400M C6
06 Tahoe LT
97 Holiday Rambler 32.5' 5TH Wheel Alumilite
96 F-350 XL 4x4 Utiliy Body 460cid E4OD
96 Honda Foreman 400
GONE 3/6/07 BUT NOT FORGOTTEN LONG LIVE THE IDI
93 F-250 XLT 4X4 4" Banks Sidewinder and Straight Pipe, Straight Axle Conversion
Supercab79 is offline
Old 03-02-2007, 10:52 PM   #2 (permalink)
Re: Some direction on the old crack alot before start problem?
normal
My Mods http://community.webshots.com/user/sconure
1996 E-350 , Bean's stage 2 injectors, 3" intake plenums, dual EGT gauge, boost, tranny, fuel pressure gauges.
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 03-02-2007, 11:35 PM   #3 (permalink)
DIESELDUTTON's Avatar
Sounds like a long time to me, mine starts in about 3 or 4 seconds when cold and in half that time when its up to temp [img]/ubbthreads/images/graemlins/shrug.gif[/img] I would check fuel pressure, hpop pressure. Does it take as long when the engines up to temp?
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 03-02-2007, 11:46 PM   #4 (permalink)
Supercab79's Avatar
No after the inital start up it fires right off. I was thinking about 2 things. First is fuel bleed back and 2nd, HPOP draining down. Once I get it home I'm going to check the HPOP res. level after sitting and fuel pressure pick up upon inital start up cranking.
Marc
06 Tahoe LT
Old 03-03-2007, 12:02 AM   #5 (permalink)
I guess thats not to bad if it fires right up after its warm. Last year mine was taking a little longer to start hot or cold since the batts were original I put new ones in and it got a little better, then I replaced the starter and it was back to normal, it would start in a couple of seconds but you said yours cranks good. I would check the basics like you said and see what happens also I just remembered when I changed my last cps it seemed to start a little quicker [img]/ubbthreads/images/graemlins/shrug.gif[/img] Good Luck
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
