Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 07-06-2008, 02:44 PM   #1 (permalink)
jimzpsd's Avatar
Starter problem........HELP
I replaced starter w/a brand new (not reman) unit, After the third time of starting the engine the starter stayed running, even after the engine was turned off. Replaced it w/another unit, and the same thing is happening. I have to remove the cables from the batts. to turn it off, and even if I remove the wires from the solenoid (on pass. fender well), the starter is still running. Can someone tell me what is happening here?
Thanks,
Jim
1997 F-350 XLT, 4wd, crew cab, E-4OD,TDE-1, 4:10's
jimzpsd is offline
Old 07-06-2008, 03:21 PM   #2 (permalink)
ammayernick's Avatar
Did you pull the smaller wire off the starter solenoid?
1997 F350 7.3 PSD Black Crew Cab XLT 4X45 Speed Manual * 205,000 miles original owner* Banks Power Pack * DP Tuner F5 Chip * Centerforce Dual Friction w/SMF * Baby Swamps Phantom II Pyrometer Fuel and Boost Gauges * Customized Dual 4" Diamond Eye SS Exhaust w/offroad pipe * Dieselsite Turbo Saver * Amsoil Bypass Filter * AFE/Tymar * Viair Onboard * Mag-Hytec Diff Cover * Amsoil Everywhere * LT315/70R17/D on M/T Classic Locks * PULSE HPOP and CPR Fuel System*
http://community.webshots.com/user/ammayernick
ammayernick is offline
Old 07-06-2008, 05:43 PM   #3 (permalink)
jimzpsd's Avatar
No, just the larger one. Is it normal for the larger wire (at the starter)to have 12 volts to it w/the key off?
jimzpsd is offline
Old 07-06-2008, 06:02 PM   #4 (permalink)
Yes, the larger wire goes directly to the battery. The smaller #10 ga wire goes to the starter solenoid on the firewall.
Old 07-06-2008, 07:19 PM   #5 (permalink)
jimzpsd's Avatar
So, are there any reasons as to why this is happening, or is it another defective starter?
jimzpsd is offline
Old 07-06-2008, 07:21 PM   #6 (permalink)
blageurt's Avatar
Starter Relay could be sticking . . .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , 3:55 D70FF, Michelin LTX " E "
Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod ,New Injector O-rings /IPR /lift pump /filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is online now
Old 07-06-2008, 07:33 PM   #7 (permalink)
jimzpsd's Avatar
If you are referring to the one on the inner fender, I had taken all the wires off of it, reattached one of the battery cables and the starter began spinning again.
jimzpsd is offline
Old 07-06-2008, 07:43 PM   #8 (permalink)
Time for a new one - starter relay that is.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
Old 07-06-2008, 08:52 PM   #9 (permalink)
Starter solenoid is stuck if you don't have 12v going to it. Did you change starter with new solenoid attached?
Old 07-06-2008, 09:16 PM   #10 (permalink)
jimzpsd's Avatar
Are you talking about the unit on the inner fender, kind of looks like the GPR?
jimzpsd is offline
Old 07-06-2008, 09:18 PM   #11 (permalink)
jimzpsd's Avatar
The new starter already had a new solenoid attached, so even w/the sloenoid taken out of the picture, the started will still spin on its own?
jimzpsd is offline
Old 07-06-2008, 10:05 PM   #12 (permalink)
blageurt's Avatar
Yes the one that looks like the GPR . . .Its like 15 bucks . . .
1990 KX500
Old 07-07-2008, 05:52 AM   #13 (permalink)
jimzpsd's Avatar
I'll install and keep you posted. thanks
jimzpsd is offline
Old 07-07-2008, 07:04 PM   #14 (permalink)
jimzpsd's Avatar
New solenoid installed and everything is ..............so far ..normal. FYI, NAPA P/N is ST-404.
jimzpsd is offline
Old 07-08-2008, 03:53 PM   #15 (permalink)
Glad ya got it sorted out.
