starter relay and glow plug relay - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 01-07-2009, 05:23 PM Thread Starter
Send a message via AIM to rockets10510
can you use a golw plug relay as a starter relay. im talking about the one of the fender?
anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
post #2 of 5 (permalink) Old 01-07-2009, 05:45 PM
chuckster57's Avatar
anthony
If I remember reading right, the relays are grounded differently. GPR is INTERNAL grounded and the starter relay is EXTERNAL grounded.. I suppose it could be done but probably not recommended..If I am wrong some one will be along shortly to correct me
Train Horns:
PM please not visitor message
chuckster57 is online now
post #3 of 5 (permalink) Old 01-07-2009, 05:57 PM
My Photos: (61)
Even if you can wire it up the amp requirements and the time engaged for the glow plug relay differ enough from the starter relay that those who have tried starter relays in their place have experienced failure in short order.
Short answer, they are not interchangeable.
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS
, LUK clutch, homemade
, open element
, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
post #4 of 5 (permalink) Old 01-07-2009, 05:59 PM
Excavator's Avatar
My Photos: (11)
A starter relay is grounded at the mounting bolts.
GP Relay is not grounded at the mount because the PCM grounds it on 1 small terminal when it calls for heat and then ungrounds it about 2 minutes later
99 F350 Super Duty CCLB 7.3 Auto DRW 150000 miles, multi disk converter,Hydra chip with TW tunes,ISSPRO EV2 pyro fuel trans
1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60, Bilsteins shocks, BTS Trans, Baby
Swamps,Tony Wildman
Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
Excavator is offline
post #5 of 5 (permalink) Old 01-07-2009, 06:07 PM
The starter relay has it's ground through the case, the glow plug relay is not grounded and has a switched ground through the PCM, so they are not the same. It would be possible to make a glowplug relay work for a starter relay. All you would have to do is ground one of the small terminals of the glowplug relay, however many times starter relays have a built in diode to suppress backspikes into the electrical system. The glow plug relay does not have a diode. You could add a diode. This is getting too much modification to be advisable I would say.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline
