Starting to get extended cranking times. CPS? - Diesel Forum - TheDieselStop.com
Old 06-26-2009, 04:47 PM   #1 (permalink)
I forget if the CPS will cause extended cranking. my tach does move a little when cranking. Not the gpr or glow plugs. I thought maybe batteries but I charged them and the thing cranks like a mother chucker so I am thinking cps. Cranks for about 3-6 second before starting. used to be 1-3 second.
96 F250 PSD ext cab SB, 5 spd 3'' DP with straight piped exhaust, tymar intake. 150k mi. Dana 60, SD v code springs, RSK
psu927 is offline
Old 06-26-2009, 07:53 PM   #2 (permalink)
blageurt's Avatar
Maybe you have a HPOP /Ipr / ICP Issues. What is the HPOP pressure when you are cranking ?
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 06-26-2009, 11:54 PM   #3 (permalink)
ccolby's Avatar
Yes, a going bad CPS can cause longer cranking time. My truck was doing this and my CPS was going bad. Now the truck starts quickly. Keep us posted, Carl.
97 F-350,4wd,cc,long bed,4.10,35's,rebuilt E40D,H2E,3" intakes,Head studs,,pyrometer,boost,trans temp,home made open intake,Joe servo IDM, Inner cooler retro,Baby swamps 170/146, Bills 3 position chip,Updated HPOP, home made oil bypass filter system, A/C mod, updated super duty fuel system, 60 gal/toobox combo.
ccolby is offline
Old 06-27-2009, 08:19 AM   #4 (permalink)
S95
my last starter faded away slowly causing longer cranking times.....because of slower cranking rpm. check you batteries and gpr for fun too.
1995 F-250 PSD 4X4 EXTRACAB LONG BOX AUTO
TYMAR FILTER, 4" MBRP STAINLESS TURBO TO TAIL
EOT MOD FOR COLD STARTS
CUSTOM RUNNING BOARDS
SD STARTER
STANDENS FULL 3 LEAF FRONT SPRINGS
1990 25th Anniversary 5.0 GT
S95 is offline
Old 06-27-2009, 01:10 PM   #5 (permalink)
97PowerJoker250HD's Avatar
CPS can cause extended cranking times, Just had mine replaced at shop and didnt know it was replaced. Started it up the day i picked it up and she had more starting zing. seemed like it cut my starting time in half.
1997 F250HD single cab long bed, 4x4, E40D w/shift kit, 4.10 gears, 3" dp to 4" stright pipe (no kitty or muffler), EBPV gutted, authentic tymar intake, Dana 50 TTB, Near future mods: (Adrenaline hpop, Stage 1 injectors, stainless steeel HPX, hypermax tapercore 7.3L intercooler, Electric fuel, and IDM mod)
97PowerJoker250HD is offline
Old 07-12-2009, 01:43 PM   #6 (permalink)
hey guys sorry it took so long to get back. I haven't even had a chance to mess with it lately so no update as of yet. I have been so stinking busy it's not funny. Anyway it's not gotten any worse yet so I'm going to get a cps and stick in the glove box and go from there.
psu927 is offline
