Steering column bearing replacement - Page 4 - Diesel Forum - TheDieselStop.com
Old 08-11-2011, 07:51 PM   #46 (permalink)
I just found this thread while searching for something completely different. I feel compelled to post something about my horrific experience! Perhaps bumping this back up will save someone the time I wasted by not finding this thread.
I did my bearings a year ago. I had no clue what was wrong (same symptoms as others), but had no choice in finding out after the freaking ignition cylinder would not get in to the "off" position one night! I had to pull a fuse under the hood to get the truck to turn off. Broke the key off in the cylinder trying to get it out. I ended up replacing the ignition cylinder, the bearings, and the upper steering column, due to the races being torn up from loose ball bearings. I found a website that specialized in fixing "punched" ignition switches, but it seems to no longer be online. The way I got the tilt springs back in was to put then in a vise and run some bailing wire through them to hold them in the closed position. I then cut the bailing wire once they were secure in the column.
This was hands down one of the toughest truck jobs I have had. Took me two days. I had several other problems too though. I did have a very small spring left over haha. Still don't know what it went to.
2001 Kawasaki ZRX1200r
1996 F-250 XLT 7.3 PSD, 4x4 Auto- TS 6 position, homemade air filter, Diamond Eye 4" system.
SpceSpff is offline   Reply With Quote
Old 08-12-2011, 07:26 AM   #47 (permalink)
Steve83's Avatar
The complete rebuild instructions are in the captions of the pics & diagrams in this album:
Walk softly & carry a BIG SIX !
Steve83 is offline   Reply With Quote
Old 12-04-2012, 09:26 AM   #48 (permalink)
Originally Posted by calamity View Post
If you have to replace the top shaft it you will need to pull the upper steering column assembly by removing it from the truck 4 13mm nuts that mount it to the dash.
If you have all of the parts it should only take a couple of hours. Good luck all of the bearings and bushings cost around $5.00 give or take a little.
OK, so to replace the bearings in the steering column I've seen reports of "it should only take a couple hours", "it took me 5 1/2 hours" to "it took me two days".
My mechanic is going to remove and bench my column assembly to replace the bearings and ignition housing. The book tells him this is an 8 hour job and that's his estimate.
Does 8 hours sound right for this job?
Mats is offline   Reply With Quote
Old 12-05-2012, 11:21 PM   #49 (permalink)
it's a big job unless a shortcut to replace the bearings without removing the shaft. If you have to remove the column from the truck, disassemble the whole thing to replace the bearings 8 hours is a minimum. Turbo speed mechanics may be out there, but there is a lot to it, and the prospect of 2 hrs to do anything is completely far fetched.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline   Reply With Quote
Old 12-06-2012, 06:57 PM   #50 (permalink)
My ignition housing is hosed along with the bearings so I'm thinking my best bet is to buy a rebuilt steering column for $350.
The guy selling these says it it would take less than 3 hours to remove the old column assembly and install the rebuilt one.
Old 12-07-2012, 05:32 AM   #51 (permalink)
'48Chevy6's Avatar
Attachment 15721
Swapping in a rebuilt unit sounds attractive. Where did you find that?
'95 F350 psd/automatic. Fueled exclusively by DRM's W85.
Junior's truck - 1970 AM General deuce and a half. The original oil burner.
'48Chevy6 is offline   Reply With Quote
Old 12-07-2012, 11:05 AM   #52 (permalink)
That photo came from this listing on ebay. That guy's website is here.
And here's another company, this one in New York, that sells rebuilt columns.
Old 12-10-2012, 05:53 PM   #53 (permalink)
After chasing my front end around and reading this, I may have this same problem. THe only difference is I notice the erratic steering and "tight" spot when I have a load in the bed, but it will "catch" and cause some pucker moments. Is there any way to inspect the bearings other than tearing the colum apart? If so, how and what to look for
1995 F-350 CC 4x4, Auto 159000.00 miles, down pipe, rusting away from the Ohio winters
deaner6670 is offline   Reply With Quote
