Steering Column rebuld - Diesel Forum - TheDieselStop.com
Old 01-19-2009, 05:12 PM   #1 (permalink)
I need to rebuld my 1994 F250 tilt steering column... Can any one tell me the best place to get parts or a kit. The tilt is real sloppy and I think the upper barings need replaced. Has anyone done it who can give me some pointers. Thanks gary
94Centurion is offline
Old 01-19-2009, 06:15 PM   #2 (permalink)
It is a Ford part only the part,Steering column upper bearing kit. Part number F6AZ-3605-AA. Hope this helps.
1997 F250 XLT CC PSD E4OD 4.10LS (AB CALI Truck)
3" down pipe
18k mod
DIY intake
2" leveling
egt,trans,boost,water,oil,oil temp,volts
Cat delete
1996 F250 XLT EC PSD E4OD 4.10LS (AB CALI TRUCK)135K
DIY intake
DB exhaust brake
HD trans cooler
ono_55 is offline
Old 01-19-2009, 10:51 PM   #3 (permalink)
Hi,
I just rebuilt my upper bearing. All the play in the steering wheel was in the upper bearing. Upper bearing service kit FODZ3L539F (does not include bearing) small upper bearing F4DZ3517A apprx 1 in. in dia. Other part numbers check the link in my sig.
Jay
97 f350 cc lb 4x4, tymar intake, new turbo, gpr, glow plugs, fuel pump 223000 miles BFG's, new rear hitch 18k, new brakes, alt, fan clutch, belt, exhaust brake, 7.3 SD oil cooler, new spring bushings all 4, new track bar bushings, downpipe, DP F5, 259000 and counting add another gpr, upgraded headlight wiring harness.
Link to PSD Part Numbers from JOAT and others.
http://www.lovnstitches.com/psdpart.php
Thank You and God Bless all active and retired members of our Armed Services!
All Gave Some, Some Gave All
97psdcc is offline
Old 01-22-2009, 06:52 PM   #4 (permalink)
okney1lz's Avatar
More Info for you!!
The other posters are right on with getting the bearing kit from ford.
After Market Shaft:
1992 - 2004 Ford F-150 Upper Steering Shaft - AM Autoparts
Hope the pdf below helps. Included is a disassembly pic from a '92 crown vic. the exploded view and the Mitchell On Demand page on the column. I especially like how Mitchell just says refer to x-ploded digram for the rebuild. What a bunch of dorks!
I'm looking for a detailed disassembly procedure myself. Please let me know what you come up with.
okney1lz is offline
Old 01-27-2009, 06:20 PM   #5 (permalink)
okney1lz's Avatar
Answered my own question...
Detailed column disassembly and reassembly instructions below.
okney1lz is offline
