Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 06-29-2009, 05:57 PM   #1 (permalink)
steering gear box/ Pitman arm
After reinstalling my radiator and a bigger trans cooler, I noticed a really bad drip of red fluid. Turned out to be power steering fluid (slight relief, but now I have a new problem) coming from somewhere around the Pitman arm. I can see the bottom of a gear between the Pitman arm and the gearbox housing. Is this normal? I suspect there should be a gasket of some sort there. The fluid leak slows to a barely noticeable dribble with the wheels pointed straight ahead, but drips pretty badly when turned hard left or right (even with engine off). TIA!
'95 F-250, 7.3L turbo DI, 4x4.
aposak is offline
Old 06-29-2009, 07:30 PM   #2 (permalink)
Yikes, looks like its your output shaft seal thats gone, never replaced that one, but i know when i was doing my suspension that the pitman arm is a ***** to take out and you NEED the right puller otherwise, good luck.
TUNINGBYAMG is offline
Old 06-30-2009, 12:02 PM   #3 (permalink)
Yeah... doesn't look like fun. They have a Pitman arm puller to borrow at the local AZ. I hope it's big enough for the truck. Is that what you used on yours, or would you recommend a different tool?
aposak is offline
Old 06-30-2009, 08:50 PM   #4 (permalink)
Lilbrown45's Avatar
My Photos: (5)
I just picked up the same tool. I am replacing my steering box. It looks to be the right size but I will throw in not to use a pulley puller! I snapped a 2 ton puller and now have a nicely sized knot on my finger.
...Tyler...
97 PSD - BIG BLUE rebuilt zf5 spd 4x4 4.10s 200k 305/70/16 - 3.5" dp straight to dual 5" stacks, DIY intake , DP FS5 60, 80, 100, 120 , pre turbo pyro, boost gauge, manual warn lockers, D60 Straight Axle, Add a leaf front, SMF LUK clutch, Solid Clutch linkage bushing, Pioneer Cd with sony speakers, xm, ipod and rca, blue led lights, custom dash. Protected by Smith and Wesson 44Mag shift knob
02 Mini Cooper (Commuter)- 5spd, DDMWorks CAI, Koni lowering spring, Megan Racing Control Arms.... Looks like a go cart in the bed of the PSD!
Lilbrown45 is offline
Old 07-01-2009, 01:10 PM   #5 (permalink)
Even witht the correct puller they can be a bear to get off. Be patient.
I tighten down the puller with an impact and hit the pitman arm with a BFH several times. Wait a while and tighten it down some more.
One thing you might want to do is leave the nut on a few threads. This will keep the pitman arm from shooting downward when it finally releases from the sector shaft.
Snowtow is offline
Old 07-01-2009, 03:48 PM   #6 (permalink)
Lilbrown45's Avatar
My Photos: (5)
I stand corrected...The puller from AZ/Kragen is not the right size! haha I ended up taking the Pitman off at the ball joint and could see the gear on the end of the steering gear was shot so I ordered the new steering gear and pitman arm (hopefully they match) and should start install tomorrow, pitman arm wont be in till friday. My front end was redone by the PO so finding parts that match has been a pain. I just took the whole steering gear and pitman in to match parts.
Question- when reinstalling should the pitman go on before i put the steering gear back in?
...Tyler...
Old 07-02-2009, 11:27 AM   #7 (permalink)
I'm thinking that the steering gearbox should go in first, to make sure the Pitman arm is aligned correctly. Not sure, haven't done it, but that would make sense to me. While you have it out, don't forget to adjust that top nut to take the slop out of the gearing.
aposak is offline
Old 07-02-2009, 03:50 PM   #8 (permalink)
As I read this it's a brand new box going in.
You can do a lot of damage "adjusting" that top nut if you don't know the exact procedure as well.
'97 F250 Supercab shortbed
Snowtow is offline
Old 07-02-2009, 08:32 PM   #9 (permalink)
Lilbrown45's Avatar
My Photos: (5)
Yes its a reman box from Astco (Autozone). I did see it came with some o-rings also???
So what is the exact procedure? I am going to wait for the pitman arm to come in tomorrow so I know they match before I dive into this. Install instructions would be much appreciated.
...Tyler...
Old 07-06-2009, 02:43 PM   #10 (permalink)
Pulled the Pitman arm this weekend with the help of an AZ rental puller and a BFH. Once the arm broke loose, it was quite easy. I took off the drag link castle nut, but didn't actually have to disconnect the drag link to get the Pitman arm loose. Put the castle nut back on and rotated the whole thing out of the way.
The seal kit I got wasn't the correct one for that gearbox, so looks like I'll have to replace the whole gearbox. At $150, it'll be a back burner project. $150 buys a LOT of power steering fluid. The leak is only really bad when parked with the wheels turned, and there's not a lot of slop in the steering wheel yet.
aposak is offline
Old 07-06-2009, 08:35 PM   #11 (permalink)
Lilbrown45's Avatar
My Photos: (5)
Glad yours was easy.. I got mine out and the new one in. Put the pitman arm on and went to bleed the system and it turns the wrong way!!! When I turn left the wheels go right. The first time I saw it, I was hilarious.. now I'm just pissed! Is there a difference between the F250 and F350 steering gear having a reverse rotation? I have the D60 (F350 front end) in my F250. The new box is a F250 box I got from AZ. I had taken the old one in so they could match it... The boxes look similar and all the holes match up but this backwards rotation is throwin me.
Highly frustrated! Pulled the pitman and reinstalled making sure it wasnt a DFO error and still the same problem! HELP! I need the truck together by Friday. I have new lines coming in tomorrow and would like to get it ready for the new linese or order new parts if I have to.
...Tyler...
Old 07-07-2009, 11:41 AM   #12 (permalink)
I checked the AZ part numbers. The '95 F-250 is a 7516, and the '97 F-350 is a 7555 (and special order, ugh). There is a difference, but the housings also look different on the 2. Not sure what year you got your front end out of. Do your tie rod ends connect to the hub in front of or behind the steering pivot? I think that's the important clue here. Can check mine over lunch if you need a reference.
aposak is offline
Old 07-08-2009, 12:13 PM   #13 (permalink)
Lilbrown45's Avatar
My Photos: (5)
Sorry for the delayed response. I'll have to check the tie rods when I get home. Does your pitman point forward or go out the back of the steering gear? If it went out the back the part they gave me would work. But mine does not use a reverse gear and goes out the front.
...Tyler...
Old 07-08-2009, 01:15 PM   #14 (permalink)
My Pitman arm points forward, and the drag link is forward of the steering gear. Drove the beast today, so I can look at anything on it if needed.
aposak is offline
Old 07-08-2009, 07:17 PM   #15 (permalink)
Lilbrown45's Avatar
My Photos: (5)
I ordered a new gear today and it should be in this evening. Before I leave the store I am going to make sure that the end shaft doesnt spin reverse. I went ahead and got new lines while I was at it. Any tips for bleeding? I am going to try to install late tonight.
...Tyler...
