Strong exhaust fumes at idle - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 01-04-2008, 07:17 PM Thread Starter
fixithud's Avatar
Truck is giving off very 'strong' exhaust fumes when idling these days.
I guess a better term would be 'rich'.
Any problem that this may be a symptom of????
Hud
95 F-350 cc xlt 4x4 srw
tymar air filter
4" exhaust with dp
gutted ebpv
kitty gone
3 position chip from Tymar, stock, tow, race.
300,000 miles in 10-08
99 F-550 xl 2x4 drw
12' Johnie Gregory Dump
six speed
stock with 230k
fixithud is offline
post #2 of 16 (permalink) Old 01-04-2008, 07:57 PM
DIESELDUTTON's Avatar
Re: Strong exhaust fumes at idle
Mine started doing the same thing at about 100k, now I have 175k and have not figured the problem out yet. I get some smoke when I start it when temps are below 40*, I think its from low cylinder temps, I plugged my truck in last night and the night before and when I fired it up there was no smoke, overnight temps were about 15*.
I have changed injectors, glow plugs, relay, etc and nothing has cured the problem. Alot of guys will say its normal, I dont think so because if it was, it would have done it the first 100k. Good Luck
Frank
2004 Pitbull Motorsports rigid chopper...Traded on 2010 F-250 5/30/14
121 TP 130rwh 250 avon
04 CRF250 mine....Gone
02 CR80 sons...Gone
03 XR100 daughters..Gone
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyone
2011 Cougar 325 SRX Toyhauler
2010 F-250 4 door 6.4 with all the fixins
DIESELDUTTON is offline
post #3 of 16 (permalink) Old 01-04-2008, 08:17 PM Thread Starter
fixithud's Avatar
Thanks for your reply...
Have you gotten your brakes straight yet??
tymar air filter
4" exhaust with dp
gutted ebpv
kitty gone
99 F-550 xl 2x4 drw
six speed
stock with 230k
fixithud is offline
post #4 of 16 (permalink) Old 01-04-2008, 08:18 PM
I think Very cold EOT ,or maybe a sticky IPR ..
Mine did that until I changed the IPR ,,(had no stinking choice) [img]/forums/images/%%GRAEMLIN_URL%%/mad.gif[/img]....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #5 of 16 (permalink) Old 01-04-2008, 08:31 PM
STurbo90's Avatar
My Photos: (9)
There was a post about a weak fuel pump casing foul smells,
http://forums.thedieselstop.com/foru...te_id/1#import
Similar posts,
http://forums.thedieselstop.com/forums/u...rue#Post1240621
http://forums.thedieselstop.com/forums/u...true#Post558485
PSD,CC,LB,E4OD,4WDw4:10LS
STurbo90 is offline
post #6 of 16 (permalink) Old 01-04-2008, 09:41 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: fixithud</div><div class="ubbcode-body">Thanks for your reply...
Have you gotten your brakes straight yet?? </div></div>
My brakes have gotten a little better since I install new front pads from the NAPA severe duty pads, but I still have not been able to work on my truck. I had 12 days off during the holidays and worked on my house finishing my upstairs (well, starting to finish [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img])I didnt even have a chance to wash my truck [img]/forums/images/%%GRAEMLIN_URL%%/mad.gif[/img].
As far as the rich smell, I to changed my ipr, map, eot sensor. By the time I figure it out, the engine might be worn out [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img], I still have not performed a compression check, but the engine runs fine and has plenty of power and doesnt use a drop of oil. I did notice recently, when the engine is up to temp the exhaust smells good, no rich smell, but to keep it up to temp I had to install a grill cover and remove the fan. I have to tow a boat on Sunday, temps will be in the low 40's and the boat is about 8500lbs so I will see how the temps are with the fan off and the grill covered. At work we have a stock 97 with 125k on it and the exhaust smells perfect, no rich smell at all, this is the truck that I have been borrowing known good sensors from [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]. Good Luck
Frank
02 CR80 sons...Gone
425 Polaris magnum
post #7 of 16 (permalink) Old 01-04-2008, 11:15 PM
Mine smells like crap too, i was going to post something today actually! I'm reading over things...seems like mine might be injector O rings (been looking at getting DIY injectors anyways, would be a good excuse to pop em out and take a look) and also the IPR, I leak a bit of oil and need to check over everything and see where it's all coming from, may be IPR orings? Hopefully not fuelpump...seems thats a big pain in the butt
'95 XLT-302-39.5 IROK's, D60/10.25-Detroits/4.88 ~7" lift
'95 4dr Bronco C150 351, '05 60/10.5 swap with 4wheel discs. ~5" lift on 315's
'95 4Dr Bronco C350 PSD-AFE stage 2 intake, Tymar 3-4" DP, 4" exhaust, EBPV delete, FPR shim, IDM mod, and Wildman 4pos chip.
JoeBob1901 on Supermotors for pics/info
JoeBob1901 is offline
post #8 of 16 (permalink) Old 01-05-2008, 12:27 AM
My Photos: (12)
a couple weeks ago i changed to a 203 tstat and that made mine smell a lot better, not that that was for sure the cause of the stink but it did a good job covering it
86f2504x4,6.9, hypermax turbo, cowl induction, 3.5 hypermax exhaust, c6 3.55 std cab
97 f250 psd 4x4 ex cab, auto 4.10ls wildman tunes
rthomas is offline
post #9 of 16 (permalink) Old 03-29-2011, 10:10 PM
Would someone shoot me a pm if they fixed there stink problem, mines been this way for months,, really bad odor,,, runs good,, send me a pm if you did something fixed your problem,,, t hanks
myred is offline
post #10 of 16 (permalink) Old 03-30-2011, 12:09 AM
I realize most of you guys are Ford men but i am having an issue with my 04 Chevy Silverado 2500HD. I have smoke coming from the exhaust even just sitting at idle. It has that "rich" fuel smell to it. Ive read a couple of forums and i keep hearing that this could be an injector problem. I did however recently have a code pop up "fuel rail system" when i scanned the check engine light. Well the check engine light went off, yet i am still having smoke constantly out the exhaust. Seems you guys are having the same issue so i was wondering if any of you were able to figure out the issue????
sundancekidesco is offline
post #11 of 16 (permalink) Old 03-31-2011, 06:00 PM
When I bought my truck , it stunk like that also , within a week or two , the IPR crapped out . The new one for some reason ,took away the odor also ...
Rick.....
post #12 of 16 (permalink) Old 03-31-2011, 09:13 PM
FordFisherman's Avatar
My Photos: (5)
What oil are you guys running that are having issues with "rich" fumes? I'm getting the same thing and running rotella 15/40.
96 F350XLT 4x4 Auto 7.3 Straight 3.5 exhaust 3:55
DIY Intake, 3" downpipe, SCT tuner, Pyro Boost Trans Gauges-Front add-a leafs, Dieselsite Coolant Filter-265,000mi.
FordFisherman is offline
post #13 of 16 (permalink) Old 04-02-2011, 12:18 AM
kwcat's Avatar
Send a message via MSN to kwcat Send a message via Yahoo to kwcat
All you guys need to check your IPR's HPOP's, and fuel pumps, injectors are loading up because of low pressure at idle, the one with the 6.6 duramax, you may have an injection problem like the old 6.2 and 6.5 diesels.
1991 F250 IDI E4OD
1995 F350 POWERSTROKE E4OD 4x4
kwcat is offline
post #14 of 16 (permalink) Old 04-03-2011, 12:44 PM
@kwcat
I ended up taking it to the dealership, and from their diagnosis it is the injectors.
post #15 of 16 (permalink) Old 04-03-2011, 02:11 PM
kwcat,, what am i looking for?? hpop has oil it it. i believe the guy i bought it from said he replaced the injectores or the dealer did .. When i first bought the truck year ago i never noticed the rich smell coming out of the excaust
myred is offline
