Suspension on the front passenger side Saggin. - Diesel Forum - TheDieselStop.com
Old 03-02-2007, 09:48 AM   #1 (permalink)
It looks like that side is saggin. Everytime I park and and look at the truck from the front it always looks like the bottom of that tire is kicked out and that side is always lower than the drivers side. Could it be that the coil spring is tired or is this normal. And if it is tired where could I find a replacement. I would just like my truck sit level parked and when driving. Any info would be greatly appreciated. Sorry for all of the questions. Thanks guys.
97 F-250 125,000 miles and counting Banks Big Hoss 100hp chip, Banks Quick Turbo Housing, Banks Transcommand,Stainless bumper guides, Stainless nerf bars, Stainless Brush Guard, Cobra 29 W/ Wilson 1000 Mag mount
ejpowerstroke97 is offline
Old 03-02-2007, 09:58 AM   #2 (permalink)
stroker101's Avatar
Re: Suspension on the front passenger side Saggin.
depending on the front end you have under your trk (2X4 or 4X4)... defective ball joints?
97 F-350 XLT*7.3L PSD*2X4*BLK*CC*DRW*E4OD*4.10 Gears*Alum. Whls*TYMAR HX mod*Open Air Intake(Tymar copy)*LONG Tru-Cool Trans Cooler #LPD47391*3" DP* Magnaflow 4" S/S exhuast w/5" polished S/S tip*TS-Perf. 6-position chip*Hide-Away Gooseneck hitch*LT235/85R/16*3GA.Pillar Pod/ISSPRO(exh.temp,tranny temp,turbo boost)*Billet Grille*SMITTYBILT Chrome Step-bars*
06' Dodge Ram HD 2500,SLT,4x4,Wht,Quad cab,5.9L CTD,short box,5" Magnaflow exh. w/6"tip,35/12.5-17" BFG A/T M/T,Cool Hose(blk),DTR intake elbow,K&N filter,Dash mounted ISSPRO ga.boost,pyro,tranny),BDTD tuner,Diablo Power Puck,Tuff Country 2.5" lvl kit,Rhino whl-whl step bars,Rhino liner,Defiant steering brace
stroker101 is offline
Old 03-02-2007, 10:56 AM   #3 (permalink)
It is a 2x4. But I have my truck aligned regularly by a reputable alignment shop and they always tell me that my front end is in great shape. How do I check that my self?
Old 03-02-2007, 05:56 PM   #4 (permalink)
I am not sure on the 2x4 but I know on the 4X4 (twin I-beam suspension) the center pivot bsuings go bad on that side since the arm is longer and then even with good ball joints the trucks body lines won't match and the bottom of the tire will kick out and eventually the outside half of the tire will never touch the road. Hope that helps.
Daniel
2004 Dodge Ram 3500 HD, SLT, Sport, Crew Cab,long bed, 4x4, 67k, 5.9L cummins, 6spd. Manual,Infinity 6-disc sounds system, 40/20/40 Seat, Power Windows, Locks, Tinted windows, Line-X bedliner,Bug Deflector, Diamond plate bed boxes, B&W flipover hitch. 29mpg/23mpg city/hwy.
Carfinder4u is offline
Old 03-03-2007, 09:22 AM   #5 (permalink)
stroker101's Avatar
just before the balljoints on my trk were c/o, the alignment tech brought me out in the shop where my trk was on the lift(zero weight on the front tires). he then showed me how the balljoints were worn by placing a long solid bar under the tire(s) and lifted up on the tire. [img]/ubbthreads/images/graemlins/eek.gif[/img] there was alot of play. i'm surprised that the front end didn't fall apart.
you could probably do the same. support the trk with jack-stands. not to say that you would not work safely, but safety is always priority.
good luck
