thermostat, water, leaking issues... - Diesel Forum - TheDieselStop.com
Old 08-25-2009, 12:12 PM   #1 (permalink)
DABOSS's Avatar
Aloha Folks,
about 1 1/2 years ago I installed a new water pump. At the same time I replaced the thermostat housing and the t-stat with one of those 205 ones. Well, I think the seal between the housing and the top of the water pump has sprung a little leak.
I did not see a big difference in having the 205F and it seemed more problematic to me just in terms of it mating well so as to not have any leaks.
I am thinking about replacing the t-stat now and wanted to ask you which one you would recommend? The Ford one which I believe runs at 192F or something else that will replace the original stock one and not have the issues that the 205 one has.
Thank you as always.
Mahalo!
'96 F250 XLT, 4WD, Ext Cab, 4.10, D60, RSK with SD Springs, Bilsteins, ATO Performance Transmission E4OD, Heavy Duty Transmission Cooler, Tymar Intake, Tymar 3x4 DP, Tymar Coolant Filter, no "kitty", gutted EBPV, FS2500 Bypass Filter, USA Made Powermaster Denso 9051 Starter!...
http://community.webshots.com/album/578027416pkIMRS
DABOSS is offline
Old 08-25-2009, 12:40 PM   #2 (permalink)
Send a message via AIM to rockets10510
i bought the 203 ones from dieselsite.com and have not had a problem. you could change it out to what every you prefer i would guess...
anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
Old 08-25-2009, 08:45 PM   #3 (permalink)
I had the same problem as you.. My old t-stat was still good an all but it was leakin, So when I went in to fix the leak, I just put a new 195* one back in my truck and sealed it with some good gasket maker stuff.. No leaks so far.
1989 Dodge 250LE, 4x4, cummins, stright piped, pump tweaked, more mods in the future
my new toy, 1996 f-350, crew cab, 7.3 diesel, 5spd, mods in the future
TractorMike is offline
Old 08-25-2009, 11:40 PM   #4 (permalink)
DABOSS's Avatar
Aloha Folks-
thanks for your replies. I just want something here that I do not have to mess with too often and works and is reliable. I would love to spend more time on other things like installing a Tony W. Chip!
Did you get your 195* T-stat from an auto parts store?
Mahalo,
Kyle
DABOSS is offline
Old 08-26-2009, 01:36 AM   #5 (permalink)
pjwoolw's Avatar
My Photos: (5)
The Ford / Motorcraft stat has the seal integrated on the stat. Much easier. Get a new housing too. They are hard to reuse. I got some allen head bolts to replace the OE ones. Allot easier to install. Take it easy and don't over torque the housing. Use an inch pound torque wrench if can get ahold of one.
Pete in San Ramon
2005 F250 6.0 Lariat 4X4 CC short bed (Stock)
1997 F250 7.3 XLT 4X4 Reg. cab (Stock)
1986 F250 6.9 XLT 4X4 Gone but not forgotten
pjwoolw is offline
Old 08-26-2009, 04:06 PM   #6 (permalink)
Question
Pete, what size are thouse allen head bolts to replace the OE ones? Thanks
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
Old 08-26-2009, 04:50 PM   #7 (permalink)
Jcart's Avatar
As a suggestion you might want to put a goodly amount of anti-seize on the bolts prior to install, then they will not seize and twist off in the housing next time round...
jrc
97 XLT F250 CC ZF-5 (now ) DIY short shifter 355's D60 air locked T Wildman files, 'jectors, SD Hpop, DIY E-fans, IC, DP 4" exhaust, SS resonator, RSK, SD springs all corners, Velvet rides, Custom Aluminum Drybox/fuel tank, air bags, E-air compressor, VisionX HID/LED's, E fuel, F26D rear tank, E-fan Tranny oil cooler.
http://community.webshots.com/user/jcart44
Jcart is offline
Old 08-26-2009, 07:12 PM   #8 (permalink)
pjwoolw's Avatar
My Photos: (5)
X2 on the anti seize. I'll check that bolt. It is metric.
Pete in San Ramon
pjwoolw is offline
Old 08-26-2009, 08:22 PM   #9 (permalink)
pjwoolw's Avatar
My Photos: (5)
The bolt has a 5mm allen head. Not sure what equates to as far bolt size and thread pitch.
Pete in San Ramon
pjwoolw is offline
Old 08-26-2009, 09:57 PM   #10 (permalink)
Talking
X3 in the suggestion of the anti-seize.
Ok, Pete, dont worry, thanks a lot.
Old 10-24-2009, 06:00 AM   #11 (permalink)
DABOSS's Avatar
Aloha Pete-
Thank you for mentioning the new Ford Thermostat for our vehicles and how they have the integrated seal on them so that I do not have to use the separate seal/gasket on top of a thermostat without that integrated rubber seal.
Mahalo
DABOSS is offline
Old 10-24-2009, 12:52 PM   #12 (permalink)
pjwoolw's Avatar
My Photos: (5)
Your welcome! Does make things allot easier.
Pete in San Ramon
pjwoolw is offline
Old 10-24-2009, 01:06 PM   #13 (permalink)
FTEMIXER's Avatar
Have that same issue, I installed a new t-stat, gasket, and housing(outlet pipe off the top of the pump). Now it is leaking. Should I use some silicon gasket stuff or just buy all new at Ford? The parts I just bought are from Napa. What are the torque specs for the three bolts? Man, weather changes and new problems arise, got to love it. Thanks for any input.
1995 2wd supercab longbed, 3"downpipe to 4",Aeroturbine muffler,baby swamps,Tymar intake,Tymar HPX,Tymar coolant filter,Hayden big tranny cooler,08' alluminum dif cover,Autometer gauges,gutted ebpv,air horns, used to pull a 30' travel trailer.
FTEMIXER is offline
Old 10-24-2009, 06:50 PM   #14 (permalink)
pjwoolw's Avatar
My Photos: (5)
If you didn't get a new housing you'll probably need one. The Ford / Motorcraft thermy is the way to go. The torque spec is 15 ft lbs.
Pete in San Ramon
pjwoolw is offline
Old 10-25-2009, 02:16 PM   #15 (permalink)
Zrock's Avatar
Had the same problem. Went and grabed some watterpump gasket maker. Put a thin line on put everything back togeather but did not tighten just snug. Let it sit for 1/2 hour then tightened. No more leak.
1995 F250 Powerstroke
Zrock is offline
