Time for a new rear fuel tank. - Diesel Forum - TheDieselStop.com
Old 05-31-2009, 06:34 PM   #1 (permalink)
DIESELDUTTON's Avatar
Today I noticed fuel dripping from the rear tank guard, I dont want to lose the spare so I guess athe Bronco tank is out. Who sells a stock style replacement and do they make them in poly or are they all steel. Thanks Guys
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 06-01-2009, 10:09 PM   #2 (permalink)
if you want to try something different without changing the tank.... my rear tank was leaking where the support was rubbing on it so i used this stuff called Seal-All from Napa ( it is in a yellow tube ) and then but a piece of rubber intertube i cut up between the tank and support and have not seen a drop since. i was leaving some pretty good size diesel slicks and i did not think this stuff would work but, it's been since just after easter now and is still not leaking. my leak was right on the bottom and had fuel dripping out as i was smearing some of this stuff on there so, like i said, i was really surprised it worked as it did. if you want though, i know that napa also sells the replacement tanks but they are only steel. i've seen ads for companies that sell oversize poly tanks but don't know as much about them.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline
Old 06-01-2009, 11:05 PM   #3 (permalink)
Thanks, I might give that a shot until I have time to replace the tank. Thanks again
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
Old 06-02-2009, 02:29 PM   #4 (permalink)
Talking
Frank
Did you know where the leak comes from?, mine leaked when I filled up, and turned out that the clamp of the intake hose was a little loose, I thightened it and no more leaks. I hope this helps you.
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
Old 06-03-2009, 07:43 PM   #5 (permalink)
I did notice the leak after I filled up, I will take a look tomorrow. Thanks
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
Old 06-03-2009, 09:32 PM   #6 (permalink)
Wink
Frank
you are welcome
keep posting
