Towed home again - Diesel Forum - TheDieselStop.com
Old 10-28-2009, 07:42 PM   #1 (permalink)
SKYGRABBER's Avatar
Thumbs down Towed home again
I got towed home 2 weeks ago when my truck was seeming to miss on my way into work and on my way home it missed then died. I was able to restart it but it would die within seconds so it went home on the hook. Then I realized my water pump had a small leak and could have shorted the CPs so I blew it out and it started right up.
Next I swapped the pump and left for vaction(one week another truck) and then came back added coolant and so on and too the truck for a spin and now here I sit waiting on another tow. It I hit the bleader and looked around the truck, drained some of the water seperator and then it started only to drive 500 feet and now won't start at all.
What to do?
97 F350 CC LB PSD AIC 4" Superlift 2" reverse shackle 44" dick cepecks custom bumpers and headache rack Rancho 9000 shocks 4 in straight pipe and soon to add DP (old style)
(new style) Utility bed, 37" MTR
2000 excursion black to match
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1976 1 ton chevy dump
1979 chevy c50
http://community.webshots.com/user/skygrabber
SKYGRABBER is offline
Old 10-28-2009, 07:57 PM   #2 (permalink)
harleywgcple's Avatar
camshaft position sensor
2004 King Ranch Dually Head Studs, EGR Delete, Upgraded Uppipe, Oil Cooler, Auto 4:10 Gears, upgrade fuel spring,6.4 banjo bolts upgrade, Fuel pressure guage, Edge Evolution
harleywgcple is offline
Old 10-28-2009, 08:14 PM   #3 (permalink)
realbadlarry's Avatar
or the IPR wiring harness. Check for a loose connection there..do a wiggle test with someone trying to start it while you wiggle the harness....worked for mine.
95 CCLB 4X4, DP, TYMAR, Adeneline HPOP, 5POS CHIP, 4",3 GUAGE POD, 129k, 265/75/16 bfg E, E4OD,4.10s,Putnams hitches front and rear,Air bags rear.Banks IC
realbadlarry is offline
Old 10-28-2009, 08:20 PM   #4 (permalink)
SKYGRABBER's Avatar
What is ipr. I tried my 2000s cps but that didn't work I ordered a new one for tomorrow. This is getting old I need the truck to start making me some money again. Any help would be great.
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 10-28-2009, 10:12 PM   #5 (permalink)
Before you throw parts at it...do you see 200 or so rpm on the tach? Do you see any smoke while trying to start?
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 10-28-2009, 11:19 PM   #6 (permalink)
SKYGRABBER's Avatar
K I will check tomorrow if so?
If not?
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 10-30-2009, 03:17 PM   #7 (permalink)
This happened to me once...low on oil...
SA.
96 F-250 PSD, Ext Cab, 4X4, 3.55; Rebuilt E40D Tymar open air element; Stancor 586-902 heavy duty GPR; Beans Electric Fuel; Baby Swamps; Gutted EBPV; DPPI DP; Autometer Z-series Gauges; Rockin S gauge pod; Tymar 4" cat back exhaust system;
SArchie is offline
Old 10-31-2009, 12:29 PM   #8 (permalink)
SKYGRABBER's Avatar
CPS is swapped truck started right up and I left it running for about a half hour and then went around The block once but now I'm just gunshy about driving it, anything else to look for.
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 11-03-2009, 07:08 PM   #9 (permalink)
SKYGRABBER's Avatar
Dieing again whatelse can I do?
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 11-03-2009, 07:41 PM   #10 (permalink)
Unplug the ICP sensor left side of the motor near the lifting ring, Try starting , look for oil leaking from the sensor . Next , may need to get it on a PSD capable scanner . watch ICP pressure & IPR DC % at stall ..
My WAG is the IPR is sticking ....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 11-04-2009, 01:51 PM   #11 (permalink)
SKYGRABBER's Avatar
Can't tell if oil has leaked from that sensor it's dirty and grungy but could be from somthing else but when I unpluged it truck started right up but showed The check engine light. What's next
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 11-04-2009, 01:55 PM   #12 (permalink)
SKYGRABBER's Avatar
Also the deal that threads into the fuel filters housing that has the wire coming out of it on the leftside of the motor is leaking diesel can I pull that off and reseal the threads and put it back?
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 11-04-2009, 02:34 PM   #13 (permalink)
When you have a stall , is it while idling or driving or both?.
Still might need a scanner ..
Rick.....
Old 11-04-2009, 03:06 PM   #14 (permalink)
SKYGRABBER's Avatar
it stalls while driving it will just cut out and sometimes i can push down on the throttle to power out and it may pick up and run again and clunk but the eventually die and completely shut off. But it seems if i let it sit it seems to start up and if i let it sit and idle it seems ok. i vaguely remember a month or so back it was missing on idol sometimes cause i watch the rpms fluctuate(on my aic) and then it would smooth out. is there a way to test the cam sensor maybe i got a bum one (unlikely). also will the scanner show anything with no engine light on.
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 11-04-2009, 04:09 PM   #15 (permalink)
CPS have been known to be bad out of the box , get one from international if you can ...
Rick.....
