Towed home again - Page 2 - Diesel Forum - TheDieselStop.com
Old 11-04-2009, 05:32 PM   #16 (permalink)
SKYGRABBER's Avatar
What else do you think it could be and can I test my new cps
97 F350 CC LB PSD AIC 4" Superlift 2" reverse shackle 44" dick cepecks custom bumpers and headache rack Rancho 9000 shocks 4 in straight pipe and soon to add DP (old style)
(new style) Utility bed, 37" MTR
2000 excursion black to match
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1976 1 ton chevy dump
1979 chevy c50
http://community.webshots.com/user/skygrabber
SKYGRABBER is offline
Old 11-04-2009, 05:42 PM   #17 (permalink)
IPR sticking & there is no test for CPS (that I know of) other than try a new one . Need a scanner...CPS is cheap test , ICP a bit more , IPR ,quite expensive . Need some data from a scanner at no start...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 11-05-2009, 01:43 AM   #18 (permalink)
SKYGRABBER's Avatar
Are the cps from a 2000 psd the same as the 1997?
Can I use it to see if that's my problem?
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 11-05-2009, 09:10 AM   #19 (permalink)
I don't know for sure ...
Rick.....
Old 11-05-2009, 10:12 AM   #20 (permalink)
SKYGRABBER's Avatar
Can the icp or ipr be pulled and tested or any other methods to try. I'm going to call some people today about getting it scanned but I know it's not going to be cheap so if I can nip it in the but before that would be good.
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 11-05-2009, 11:57 AM   #21 (permalink)
THe Coil on the IPR can be tested , but not the valve , I think no the ICP as well . A scan will tell most of what you need ...
This is from member Pocket:
you have to view the ICP. When my truck wouldn't start, I watched ICP pressure, voltage, and duty cycle along with the engine RPM's. I cranked for about 10 seconds or so, and watched as the ICP voltage and duty cycle increased, but the pressure did not. It stayed between 100-130 psi no matter what. That told me that as voltage and duty cycle increased, the IPR was not responding and maintaining pressure. If it was a voltage issue, then it would have been the ICP sensor itself.
If I remember correctly, to start you need at least 400 psi of high oil pressure, and 0.8 volts on the ICP.
Rick.....
Old 11-05-2009, 12:01 PM   #22 (permalink)
This is not the prevelent thought process (we like to fix them ourselves), but take it to a Ford or International dealer, or a private diesel mechanic with proper scan tools.
Lost 2 weeks work with my rollback, threw new parts (Supply pump) at my '96 7.3, almost bought a used HPOP with IPR, then finally took it to the dealer where they put an IPR on the HPOP. Tech commanded the IPR with his scan tool and saw it wouldn't let the HPOP make over 150lbs (sticking open letting oil go back to the crank case).
I'm not saying an IPR is your problem, but for $80, I got a diagnosis, got to talk to the master diesel tech twice, and got a guarantee my truck would start and run.
As for your fuel leak on the canister bleeder valve, put a steel valve stem cap on it.
'96 F350 Rollback
popinky is offline
Old 11-05-2009, 01:39 PM   #23 (permalink)
SKYGRABBER's Avatar
Hey pop thanks but it's not the bleeder it's the one next to itwith the wire coming out.
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 11-05-2009, 06:19 PM   #24 (permalink)
SKYGRABBER's Avatar
codes
P1280 icp out of range low
p0603 internal control module
p0344 cps fault
p0340
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 11-05-2009, 07:14 PM   #25 (permalink)
SKYGRABBER's Avatar
New icp still wouldn't start played with cps conector started up. Clearing the codes and rechecking.
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 11-05-2009, 07:27 PM   #26 (permalink)
Real time data is what we need ...
Rick.....
Old 11-05-2009, 07:28 PM   #27 (permalink)
SKYGRABBER's Avatar
It died again and seems to do so at a certain temp
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 11-05-2009, 08:32 PM   #28 (permalink)
SKYGRABBER's Avatar
What data is needed I saw the icp voltage while running 2.30vcouldnt find oil preasure.
1951 f1
1952 f2
1967 cj 5
1968 chevy stepside
1979 chevy c50
Old 11-06-2009, 09:45 AM   #29 (permalink)
Does it start right back up again , or does it need to cool down first...?
Rick.....
Old 11-06-2009, 09:47 AM   #30 (permalink)
You need to watch IPR duty cycle % as it compares to ICP pressure. May want to note EOT as well ...
Rick.....
