Old 11-06-2009, 09:27 AM   #31 (permalink)
SKYGRABBER's Avatar
When it dies it won't refire but if I let it sit for 5-10 it will start right up and drive for a bit. As for the scan I will try it agin next week.
97 F350 CC LB PSD AIC 4" Superlift 2" reverse shackle 44" dick cepecks custom bumpers and headache rack Rancho 9000 shocks 4 in straight pipe and soon to add DP (old style)
(new style) Utility bed, 37" MTR
2000 excursion black to match
1951 f1
1967 cj 5
1968 chevy stepside
1976 1 ton chevy dump
http://community.webshots.com/user/skygrabber
SKYGRABBER is offline
Old 11-06-2009, 09:32 AM   #32 (permalink)
midwestconnection's Avatar
Never rule out something floating around in your fuel tank and being sucked over the fuel feed line and then letting go after the suction lets off after the motor dies and some time to let loose and then does it all over again and again.
Bumper to bumper, Full Synthetic!!! Rotella T 5-40(7.3L) -- Mobil 1 Mercon V(E40D) -- Amsoil Extreme 75-90(Danas 60) -- Detroit Lakes, Minnesota -- "Boating has always been a rich mans hobby". -- 1996 E350 XLT Club Wagon 15 Passenger Van. -- Purchased 10-21-2009 for $700 cash with 620,000 miles on it! -- It's mint and beautiful! -- I love it! -- I am 64 years old and a professional mechanic and truck driver for over 45 years. --I am now a rich man driving a $50,000 prime time Ford that gets 21 MPG(HWY) & 16 MPG(Town).
midwestconnection is offline
Old 11-06-2009, 03:13 PM   #33 (permalink)
Originally Posted by SKYGRABBER View Post
New icp still wouldn't start played with cps conector started up. Clearing the codes and rechecking.
Just suffered through this a couple of months ago. With my old (rip) engine, i never had a cps issue. Never. Swapped over the ol trusty cps and entire wiring harness into the new engine and toasted my 15 year old cps on her maiden voyage. Threw numerous cps's at this thing over the course of 2-4 weeks, including IH sensors and a Superduty cps as well (gold contacts, white in color). Turned out, after a ride home on a roll-back, and I just about had enough of this crap, one of the 3 wires, i think pin C, was broken inside the connector and was making intermittent contact. My truck would not act up when cold, only after it warmed up. With that said, disconnect your cps and measure ground/dcv at the pins while wiggling the connector/backshell/wires and see what happens. Pin A to ground key off, pin B .5vdc koeo and pin C 12vdc koeo. If this is your problem, i will provide you with a cps connector/pig tail repair kit part number from FoMoCo.
Good luck..
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 4:10 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP 1.0 exhaust housing * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 11-09-2009, 01:00 PM   #34 (permalink)
SKYGRABBER's Avatar
Randy
Thanks i checked that and i seem to be getting current and no broken wires
BUT now being cold and having sit since thursday night it just cranks with no start i tried jumping the gpr to see if maybe that went out due to the guy scanning the truck leaving the key forward for a while which i know is not good and i also heard a weird sound coming from the realy or near by like a loud ticking or a contactor chattering.
im getting fed up and need to get back to work any more suggestions.
1951 f1
1967 cj 5
1968 chevy stepside
Old 11-09-2009, 01:20 PM   #35 (permalink)
SKYGRABBER's Avatar
i just tested the relay according to a previous post
12v main lug
key on powers up large lug across from it
powers up little lug to the left of it
after relay turns off has main lug on and 2 small lugs the other large lug has no current even when cranking
could this also be a problem of shutting down my glow plugs when the relay gets hot and in turn kills the truck?
1951 f1
1967 cj 5
1968 chevy stepside
Old 11-09-2009, 05:34 PM   #36 (permalink)
Your gp relay appears to be operating correctly. Plug in the block heater to aid cold weather starting. Also, if its really cold, cycle the plugs a couple of times...the down side is that a serious drain will be placed on your batts....but you need to have them on charge anyway.
Randy
Old 11-09-2009, 06:27 PM   #37 (permalink)
SKYGRABBER's Avatar
Thanks Randy I did jump the glow plug relay to try and been charging the batts and all it wants to do is crank I may have to set up a gauge on the schrader to see if I have enough preasure
1951 f1
1967 cj 5
1968 chevy stepside
Old 11-09-2009, 06:33 PM   #38 (permalink)
Extended cranking with no start can deplete the hpor. Dont forget to keep an eye on its level.
Randy
Old 11-09-2009, 07:35 PM   #39 (permalink)
SKYGRABBER's Avatar
Can it be the fuel pump? Would thy have the same symptoms?
1951 f1
1967 cj 5
1968 chevy stepside
Old 11-09-2009, 08:17 PM   #40 (permalink)
What is your pressure? I have seen fuel pumps start a truck fine and idle all day long, but when you mash the go pedal, it falls on its face...monitor while driving to be sure.
Randy
Old 11-09-2009, 09:32 PM   #41 (permalink)
SKYGRABBER's Avatar
How do I check that?
For the preasure I need to get a liquid filled gauge and pull the scrader.
But I will only get cranking preasure. Cause it still won't start
1951 f1
1967 cj 5
1968 chevy stepside
Old 11-09-2009, 10:34 PM   #42 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
Pull the plug on top of the HPOP reservoir (rectangular box-shaped thing on top/front of motor). It should within 1/2 inch from top.
You need to know if the cranking pressure is sufficient, and if it starts you will want to try and check it a WOT (tape the gauge to the windshield). I've had fuel pumps fail on the high pressure stage where it would idle all day but go to zero at WOT. Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 11-09-2009, 11:08 PM   #43 (permalink)
SKYGRABBER's Avatar
And if there's no or low oil?
Anyone know where to get a gauge?
1951 f1
1967 cj 5
1968 chevy stepside
Old 11-10-2009, 02:21 AM   #44 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
If the HPOP oil level is low refill it through the plug hole with fresh oil. You can get a fuel injection pressure gauge from Advance Auto, Autozone, O'riellys, NAPA, etc..
97 F-350,4X4, CC, LWB, PSD, 251k, K&N, 10K MOD
speeddemon31176 is offline
Old 11-10-2009, 03:39 AM   #45 (permalink)
As stated, if the rez is low, just top it off. But be mindful of the crankcase level. If you have to add oil a few times to the rez, the effect will be an overfull crankcase....which reminds me...your crankcase oil level is good right?
Randy
