Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
Yes, that relay chatter needs to be addressed. Pinpoint which one and let us know.
Randy
ok found the diagram for the 4 relays in main power block but what are the 2 on the side
i nalso swapped the number 2 and 3 relay (horn and idm) still no start and there is oil in the hpor
what to do next i have notced some oil on two of the injector plugs going to the passenger side rear atop the valve cover and driver front (cant get to rear driver due to intake)
97 F350 CC LB PSD AIC 4" Superlift 2" reverse shackle 44" dick cepecks custom bumpers and headache rack Rancho 9000 shocks 4 in straight pipe and soon to add DP (old style)
Still not started had it pluged in for a while too going to hook it up to a scanner and fuel pressure gauge tomorrow and see whats up im stumpped though seing that i drove it back and now it just cranks
Do you see smoke when cranking? If not, you are not fueling due to hpo, electrical or fuel itself.
Do you have the normal lights (cel, wts) when the key is turned over?
Are you keeping the batts on charge? The pcm needs to see 10vdc to unlock...
Crankcase oil level and hpor level are important. If you add to the hpor, it can overfill the cc if repeated.
You do have suffecient fuel...and not gasoline right? (it has happened)
Need to check fuel pressure.
Let us know.
Need to verify all fuses and maxi fuses are not toasted.
Randy
The two relays on the side are for the trailer plug setup.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
hooked up gauge dont seem to be getting any pressure but i know when i depress the schrader it get spurts (maybe the gauge line needs to fill will diesel to regester but batteries are back down time for new ones)
hooked up the scanner and it threw 2 codes
p1661 out put ckt
p0603 internal ctrl module kam error which i believe was poresent last time
anythoughts
also one of the pigtails that has oil on it going through the vc smells burnt
Update pulled the pass vc and the rear plug feeding the rear 2 gps was burnt going to pull driver side sun but before I get two new batteries and new vc kits could this be my problem? Or is it just another problem I read that the icm or idm shuts down when it has a short? I'm not in the best financial posistion right now and maybe that money would be better spent somewhere else.
