trans wire harness & blown fuses - Diesel Forum - TheDieselStop.com
Old 02-19-2010, 02:47 PM   #1 (permalink)
bullyandbif's Avatar
Going down the road and the truck all of a sudden dead. Get it pulled over and find the #9 maxi blown.
Now a few days ago I had #22 blow and unplugged the heater and all was well till now, so I figured it was related so I taped off the heater wire thinking of a short or something, and replaced the #9.
It stared fine except the od light was flashing and trans didnt shift right.
So I limp home a couple mile and after crawling under and finding a massive icepack between the trans crossmember/skidplate and all the trans stuff I found the ice had shoved the wireharness into the 4x4 driveshaft from transfercase and wore through some wires. I have spliced/shirinktubed/taped all back together, re-ran the harness back to it proper location w/ extra wireties to hold in place.
Would the trans wires shorting on the driveshaft blow the #9maxi? Would it have blown the #22 earlier? Do you think I need to check/inspect anything more before I call this incident over?
Thanks,
bullyandbif
'97 F350 201K , IDM mod.,shim FPR,gauges,ford reman trans @ 198k
bullyandbif is offline
Old 02-19-2010, 04:09 PM   #2 (permalink)
midwestconnection's Avatar
Check the wire on the top of your differential. It and it's sensor will make your OD light flash if they go bad.
Bumper to bumper, Full Synthetic!!! Rotella T 5-40(7.3L) -- Mobil 1 Mercon V(E40D) -- Amsoil Extreme 75-90(Danas 60) -- Detroit Lakes, Minnesota -- "Boating has always been a rich mans hobby". -- 1996 E350 XLT Club Wagon 15 Passenger Van. -- Purchased 10-21-2009 for $700 cash with 620,000 miles on it! -- It's mint and beautiful! -- I love it! -- I am 64 years old and a professional mechanic and truck driver for over 45 years. --I am now a rich man driving a $50,000 prime time Ford that gets 21 MPG(HWY) & 16 MPG(Town).
midwestconnection is offline
Old 02-19-2010, 04:52 PM   #3 (permalink)
Mark Kovalsky's Avatar
Yes, it will, but that's not related to this problem. The VSS is NOT the cause of all problems.
I don't have a wiring schematic handy to know if that will blow the fuses that you had blow.
Mark
Mark Kovalsky is offline
