Transmission Slip - - Code P1728 ? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 11-19-2007, 06:01 PM Thread Starter
My truck is setting Code P1728. I can clear the code and it will shift normally until it gets to the point where it should lock-up the converter then sets the code. I had to drive 300+ miles to get it home and it made it ok but I'm at a loss on this. The code says Trans Slipping but it shifts so normally after clearing the code. A couple days ago it set a KAM and P1728. And about a month ago it set a Turboboost code & P1728 ( I can't find the number I wrote down for that turbo code) when it did that I pulled the pan and changed the oil & filter and drained the TC too and all was well until now.
Is there a solenoid or relay or something that could be a problem? Does this sound like a path that some of you have experienced before? The truck has 223K miles on it and is maintained religiously with the normal oil and trans services done more often than necessary and the trans fluid always comes out looking great and no burnt smell or anything metallic in the pan or on the magnet.
Any help with this will be greatly appreciated. If anyone needs more info describing this just let me know.. thanks a lot in advance.
behoof
1996 Ford F250 XLT -- TurboDiesel on BIO -- E40D 250K+ 4x4 Extended Cab "Yale, Mi"
behoof is offline
post #2 of 7 (permalink) Old 11-19-2007, 07:57 PM
Mark Kovalsky's Avatar
My Photos: (6)
Re: Transmission Slip - - Code P1728 ?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: behoof</div><div class="ubbcode-body">I can clear the code and it will shift normally until it gets to the point where it should lock-up the converter then sets the code.</div></div>
There's your answer. It's the torque converter, though it is possible that it is the torque converter solenoid, or even the torque converter control valve in the valve body. My money is on the torque converter itself.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is online now
post #3 of 7 (permalink) Old 11-19-2007, 11:51 PM Thread Starter
Mark,
Thanks for the reply.
I'm wondering what kind of damage if any I could do to this trans with having to drive it like it is until I can afford to do the necessary repairs?
What I mean is, until I can figure out for sure what is wrong and get the necessary parts to do the job?
Like I was saying, this truck has about 223K on it so is there anything in particular I could look for that may be an easy fix? You mention solenoid pack and valve, are they redily available or is this trans shop stuff? I've rebuilt a bunch of 700R's, 400 & 350THM's but never messed with one of these.
Your thoughts on all this?
behoof
behoof is offline
post #4 of 7 (permalink) Old 11-20-2007, 12:33 AM
Here is a link to a post I made about this a while back:
http://forums.thedieselstop.com/foru...397522&fpart=1
Good Luck [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
1996 F350 XLT CC LB 4x4 120K, E40D
Tymar Intake, Magnaflow 4" SS Exaust, Edge Evo, FPR Shim, SKY RSK w/SD vcodes, Bilsteins, Velvet Ride Shackles
2004 Outlander Max 400HO (mine)
2004 Rally 200 (hers)
2004 Grizzly 80 (sons)
fitzgood is offline
post #5 of 7 (permalink) Old 11-20-2007, 08:27 AM
My Photos: (6)
The most common cause of the slip code is a crack in the apply piston of the torque converter clutch. This allows pressure to leak around the piston, reducing the force that holds the converter locked. Once slip hits 50 RPM a code is set, the light flashes, etc.
If you keep driving it the friction material will glaze and it will start setting the code more often. Usually there isn't any damage to anything outside the torque converter.
If you want to try the solenoid and the valve, they are both in the pan. The trans doesn't need to come out to remove these.
Mark
Former
post #6 of 7 (permalink) Old 11-20-2007, 10:53 AM Thread Starter
Mark,
Thanks for the reply, you've got a PM
behoof is offline
post #7 of 7 (permalink) Old 11-23-2007, 12:08 AM Thread Starter
Does anyone have a torque converter for this truck? Or do you know of a place that sells replacement auto transmission parts in this area or the Detroit Area? Thanks
I'm in SE Michigan, in the Yale / Detroit Area.
E4OD/4R100 1996 7.3L TD F250 4x4
behoof is offline
