I just finished installing gauges (autometer ultra-lites) this afternoon and was wondering what is normal operating temp for the E4OD? If I remember correct it should be around 210-220. Here is the problem; My gauge will creep all the way up to 250-255 under normal driving conditions. Thinking maybe my gauge or sending unit was faulty I slaved in a autometer water temp gauge (100-250) and sending unit using new wires and the temp stays the same. The fluid level is full and only has about 10k miles on it. Is there a problem with my transmission? What would cause this? Thanks in advance
1997 F350 XLT CC SRW 4x4; 4.10's, Tymar intake, 120k. SKY reverse shackle kit. Super duty V codes front, ICON 5 inch Super Duty springs in the rear. TS 6 pos Wildman tunes. MBRP exhaust. Adrenaline HPOP. 17x8 Cepek DC-2 wheels 285x75x17 Dura Grapplers.
Way too hot for me!!
You are going to have to install a larger cooler, the stock one sucks.
I use the Tru Cooler 4590 and see normal driving temps in the 160 range.
I would be concerned if after adding a large cooler you still have temps that high.
Rick H...
__________________ Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp [color:"RED"] RDRCM#20 [/color]
I think your temps are unloaded right?, anyway I think are to high. you should check if your tranny cooler is not clogged, or better way upgrade it with a bigger one.
that plug doesnt give a 100% accurate reading of the fluid temp. the best way to do it is get a kit or a shop to install the sending unit in the cooler lines. you'd be suprised what a differnce you see, and how much quicker you see it. i would say if your gauage is reading that temp in the factory plug on the side of the tranny, your actual fluid temps could be even hotter. when i had my tranny done i had them put one in the hot side and one on the cool side coming out of the cooler. im yet to hook up another guage on the hot side though. but yes as stated before, those temps seem way too high, i would hate to see what they get to pulling any weight or sitting in traffic. aftermarket tranny coolers are fairly cheap and pretty easy to install, i would definitely look into one. good luck.
I talked to the autometer tech this morning and he said @ 250 degrees I should have 65 ohms and I had 500 so he is sending me a new one. Hopefully this will take care of it. On a funny note out of curiosity I stuck a turkey thermometer in the hole and it read about 140-150. I know this is not a accurate reading but I think if it was in fact 250 degrees in there it would have registered more. Oh well, I will know soon enough when the new sender gets here. Thanks
HIS
HERS
