Transmission -- Torque converter question - Diesel Forum - TheDieselStop.com
Old 03-03-2007, 11:47 AM   #1 (permalink)
Hi all
I have a slight leak of transmission fluid at the front seal or torque converter.
Is it worth pulling the trans to change the seal or should I change seal and converter. Worst case new trans and converter.
The trans has about 130k on it.
Thanks for your help.
Jay
97 f350 cc lb 4x4, tymar intake, new turbo, gpr, glow plugs, fuel pump 223000 miles BFG's, new rear hitch 18k, new brakes, alt, fan clutch, belt, exhaust brake, 7.3 SD oil cooler, new spring bushings all 4, new track bar bushings, downpipe, DP F5, 259000 and counting add another gpr, upgraded headlight wiring harness.
Link to PSD Part Numbers from JOAT and others.
http://www.lovnstitches.com/psdpart.php
Thank You and God Bless all active and retired members of our Armed Services!
All Gave Some, Some Gave All
97psdcc is offline
Old 03-03-2007, 12:07 PM   #2 (permalink)
Nit
Re: Transmission -- Torque converter question
what you did was overheat the fluid, it then leaks out the front seal, normally it will re-seal itself and be fine. Did you happen to bak a heavy load up a hill or do some 4x4 crawling in 1st ?, get yourself a big cooler , like a 4590 by tru-cool and change the fluid, it should be fine after that, until the TC needs to be changed out.
Sold to JCart , 1997 F250 FireTruck Red,CC SB,auto( Presicion TC, HD-2Tugger),5" exhaust, Swamp 140cc injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, ,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,she's well taken care of now pictures
2004 Dodge 3500 twin turbo 525hp rocket
Nit is offline
Old 03-03-2007, 01:13 PM   #3 (permalink)
Nit,
Tanks for the reply, The fluid is good. I did warm it up a bit in 4 low this winter busting snow banks, but it was a slow drip prior to that as well. Its been leaking for about a year now. The leak is just enough to make a mess on the driveway.
Jay
97psdcc is offline
Old 03-03-2007, 02:59 PM   #4 (permalink)
Nit
then re&re teh TC with another one and do teh seal as well.
Nit is offline
