truck just stopped while idling??? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 03-15-2007, 11:24 PM Thread Starter
my 95 ran as of 10min ago now it just cranks and no start!! the glow plug wait light no longer comes on and the check engine light is on. the relay doesnt click on and off but there is power there? I pulled the glowplug fuse and its good and when I do the check engine light goes out and the glowplug light comes on but no cycling? any ideas thanks
In the drive way> 1995 ford cc diesel dually 2wd,1987 ford 350 super duty dually 4wd wrecker,1987 chevy 1-ton diesel blazer 4wd 3" lift,2001 dodge 2500 quadcab 4wd,1979 ford 350 with 472 big block 12" lift 40" tires 4wd pullin truck! and of course the wife has a 1991 jeep cherakee with 4" lift and 33" mudders!
wrenchhead30 is offline
post #2 of 6 (permalink) Old 03-15-2007, 11:37 PM
STurbo90's Avatar
My Photos: (9)
Re: truck just stopped while idling???
I'm not sure which is which, but did you check fuse #9& 22?
PSD,CC,LB,E4OD,4WDw4:10LS
STurbo90 is offline
post #3 of 6 (permalink) Old 03-15-2007, 11:38 PM Thread Starter
yes they are both good.
post #4 of 6 (permalink) Old 03-15-2007, 11:42 PM
STurbo90's Avatar
My Photos: (9)
Getting tach movement while cranking??
do you have a chip? You could try removing it.
also if the check engine light is staying on it may just need to be scanned. The truck knows what's wrong you just have to ask it.
STurbo90 is offline
post #5 of 6 (permalink) Old 03-15-2007, 11:49 PM Thread Starter
yes the tach moves and I have oil pressure,no chip I cant get a hold of a scanner till mornin just trying to figure this thing out in my head so i can sleep tonite thanks
post #6 of 6 (permalink) Old 03-16-2007, 06:31 PM
[/ QUOTE ]Check #22 AGAIN....30 amp , under the hood....,While you are in there you can switch the smaller relays around & see if that helps...Also check the wiring to the IPR , make sure it is not grounding out...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
