truck seems doggy - Diesel Forum - TheDieselStop.com
Old 01-21-2013, 07:41 AM   #1 (permalink)
truck seems doggy
trucks completely stock. 5spd manual. i changed the fuel filter but didnt seem to help. but it just dont seem like it has the power. temp here is about -20 also could that be it? this is my first diesel ive had thru a winter.
CAT1150 is offline   Reply With Quote
Old 01-21-2013, 10:13 AM   #2 (permalink)
S95
winter diesel is not spectacular performance wise, its similar to the diference between regular and premium gas in your sports car.
1995 F-250 PSD 4X4 EXTRACAB LONG BOX AUTO
TYMAR FILTER, 4" MBRP STAINLESS TURBO TO TAIL
EOT MOD FOR COLD STARTS
CUSTOM RUNNING BOARDS
SD STARTER
STANDENS FULL 3 LEAF FRONT SPRINGS
1990 25th Anniversary 5.0 GT
S95 is offline   Reply With Quote
Old 01-21-2013, 01:05 PM   #3 (permalink)
must be the cold then? i can put it to the floor and it just crawls up to speed. before i could put the hammer down and it would dam near throw it sideways.
Old 01-21-2013, 01:59 PM   #4 (permalink)
S95
oh no, should not be that bad. winter just might make 4th feel like 5th gear feels in the summer, you might have some other issue.
give us some more details.......foot to the floor and still creeps? black smoke? white smoke, no smoke? all of a sudden takes off? is it warming up to proper temps on the guage? 0-60 used to be 10 seconds and now its 25?
SD STARTER
Old 01-21-2013, 03:34 PM   #5 (permalink)
no smoke. and yes thatd be a good way to put it on 0-60 and it hasnt really got much above the n on normal since i got it. i got it in late november tho so its been cold the hole time ive had it. i have a winter front on it. should i put some additional cardboard in front of the radiator?
Old 01-21-2013, 05:46 PM   #6 (permalink)
blageurt's Avatar
My Photos: (9)
No do not put cardboard ..you already have a winter front...Do you have a CAT ? could be plugged.... also what is your fuel pressure ? might be low ....Did you check the FPR screen ? it could be full of crap... What about the fuel filter? have you changed it ? Also when was the last time you checked the air filter ? It would be a good time to Upgrade the Intake ....Also get rid of the Stock POS downpipe......
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Michelin LTX
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
blageurt is offline   Reply With Quote
Old 01-22-2013, 08:22 AM   #7 (permalink)
no its a 1994 so no cat and also it doesnt have a muffler. just changed the fuel filter cuz thats what i thought it was and it also has a new air filter. whats the fpr screen?
Old 01-22-2013, 01:57 PM   #8 (permalink)
blageurt's Avatar
My Photos: (9)
It is a screen on the Fuel Pressure Regulator on the inside of the filterbowl...If it is clogged full of crap it reduces fuel flow.....Did you check your fuel pressure ?
Old 01-22-2013, 03:12 PM   #9 (permalink)
did not check fuel pressure yet. should i just clean that screen?
Old 01-22-2013, 11:18 PM   #10 (permalink)
blageurt's Avatar
My Photos: (9)
I would....
Old 01-23-2013, 07:48 AM   #11 (permalink)
i cleaned that screen it was very dirty also just noticed someone eliminated the fuel heater in the filter housing so ordered one of them also. it was a bit warmer this morning only about 10below truck seemed better but still if i put the throttle down after half throttle its like it didnt exist. had some pretty good pull up to half then just creeped after that..
Old 01-23-2013, 09:23 AM   #12 (permalink)
blageurt's Avatar
My Photos: (9)
Sounds like you have a weak fuel pump.....You don't need the heater....find out what your fuel pressure is...it should be 50-65...
Old 01-23-2013, 10:56 AM   #13 (permalink)
heater was only $40 so not a big deal. at noon here today ill test fuel pressure
Old 01-23-2013, 12:23 PM   #14 (permalink)
68 lbs of fuel pressure and also cleaned the lower screen on the fpr which was grosely full of debris.
Old 01-24-2013, 08:01 AM   #15 (permalink)
Thumbs up
confirmed fix after cleaning that lower filter on the fpr. truck is not even comparable to before like its got a new motor. thanks for the help.
