Trying to fix a fuel leak - Diesel Forum - TheDieselStop.com
Old 11-11-2009, 10:03 AM   #1 (permalink)
I've got a 97 F250 with a Powerstroke in it that I recently picked up. There is a fitting/sensor that is right next to the housing for the fuel filter that is dripping fuel.
I am not sure what it is called an none of the local parts stores can find what it is. It is the fitting circled in red in the image.
Can anyone point me in the right direction?
Thanks in advance!
97PowerstrokeF250 is offline
Old 11-11-2009, 10:24 AM   #2 (permalink)
Thats 1/8npt. Remove, clean threads and reinstall with pipe dope. Do not overtighten, that is an aluminum housing it threads into.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 11-11-2009, 10:27 AM   #3 (permalink)
It's actually leaking where the black plastic part mates with the aluminum housing. So I do not think I can do much of anything to repair it.
Any idea what the part is called? Is a fuel pressor sensor?
Old 11-11-2009, 10:48 AM   #4 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
It is the fuel restriction sensor and is not cheap. Most folks simply plug it with a 1/8 NPT pipe plug as was mentioned. Here's the factory part number (I've never come across an aftermarket replacement):
Fuel Filter Restriction Sensor
(Ford) E8TZ-9S283-A
Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 11-11-2009, 03:08 PM   #5 (permalink)
Yeah $66 from the Ford garage. What are the ill effects, if any, if I plug it?
Old 11-11-2009, 03:24 PM   #6 (permalink)
The dash light won't come on if the filter clogs. It's not usually a problem if you change your filter regularly.
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
webshots
RD97 is offline
Old 11-11-2009, 03:33 PM   #7 (permalink)
Lightbulb
Not at all, if you change your fuel filter in regular bases (maintenance). Mine is plugged without issues.
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
