I just bought a 95 F250 PSD, it has an awful noise at idle, it goes away when the RPM is increased. With the help of some better ears than mine it looks like the bearings in the turbo are shot. Can I install a turbo from a 99 model year truck? Any and all help would be appreciated.
I don't think a turbo from...at least a late '99, will fit our current pedestal!
There have been indications on previous posts, that you can buy a rebuild kit for our turbos, and I believe it is a fairly economical upgrade.
Most aftermarket turbo's (for our early trucks) need a fair bit of modification, or exchange of parts, thus making the whole process alot more expensive, compared to a rebuild of your current turbo.
You would probably be ahead if you just rebuilt your turbo. That way, you wouldn't have to buy a new pedestal or a turbo. Besides, our turbos are better than what comes on the superduties.
1996 F250 4x4 5sp shortbox, ats intercooler, DIY Tymar, 3" dp, Dual 5" stacks, South Bend Con-O clutch and SMFW. BDP Stage 1's up and running!!! my truck
TS 6 pos. chip-High idle, Economy, Tow, Jody Tipton Hot (75 hp), Diesel Power Extreme, and TWildman's "Move it or lose it" Extreme
"A man can always stand a little bit more horsepower" - Chris Ledoux
how do you know its the turbo making the noise [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
<font color="red"> we are not here for a long time we are here for a good time </font>
<font color="blue"> MICHIGAN POWERSTROKE ASSOCIATION </font>check it out[img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img] my picts
other toys
92 ranger extended cab with 310,000 miles
86 f-250 4x4 6.9 diesel 450,000 miles and still going strong
87 f-350 xlt 4x4 4 door 6.9 340,000
87 f-250 xlt 6.9 140,000
97 f-350 exteded cab 4x4 NATHAN P3 TRAIN HORNS two whipps, SWAMPED INJECTORS,head studs,cometic head gaskets, h2e turbo,lots of boost almost too much,joes idm, built e40d 4.10 gears,4 pos ts performance chip,open ellement air filter k&n #41-1400 hypermax 4in dp,kitty is in the litter box.10k mod shimmed,autometer gauges boost,oil pressure, pyro,trans temp, 6 in lift,6' traction bars, diamondplate toolbox, 5in stacks,lighted ford logo in the grill
Sounds like what I am going through! I had a loss of power at low rpm's and a sound at low rpm's that I thought was a sticking cooling fan clutch. One afternoon I popped the hood with the engine running and had my daughter turn the ignition off. Hearing the turbo spool down sounded like fingernails on a chalk board. Had been thinking about a turbo upgrade for some time now & I finially found justification!
'97 F350 CC, XLT, 4WD off road, 4.10, Milemarker manual hubs, Suncoast E40D w/ Bob Riley's (Dieselsite) remote filter & Triple Lock Torque Converter, Hypermax H2, BABY SWAMP'S! Swamp's 20* HPOP, Head Studs, TS 4 position chip w/ Bill's programming, Banks Intercooler. Ceramic coated up-pipes and down pipe. Triple pillar w/ Isspro boost, trans temp and digital EGT gauges. 4" Exhaust. 45gal Transfer flow rear tank. Dale Isley's HX mod. Joe Servo's IDM mod. Bob Riley's coolant filter, Coolant "T", Evans Coolant, A/C mod. Velvet-Ride's, Monroe Gas Magnum Shocks. TSM's rear disc brake kit. Frozen/ Slotted front rotors with Hawk Pads. Centramatic Wheel Balancers & 285/75/16 Michelin LTX/MS. Interior sound deadening (what a difference!).
