Turbo Oil Leak Drainback - Diesel Forum - TheDieselStop.com
Old 01-17-2007, 12:32 AM   #1 (permalink)
The oil is leaking when returning from the turbo. Seems to be where it goes into the pan. Also, is there a website I can locate a diagram? (Have 1999 F250 but should be the same as 1997.) Thx.
earld444 is offline
Old 01-17-2007, 01:28 AM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
Re: Turbo Oil Leak Drainback
Welcome to the forum! There is a forum for the 99+ models, but your oil leak could be from a number of sources. There are o-rings on the pedestal where the pedestal mounts to the block and where the turbo mounts to the pedestal. There are also the High Pressure Oil rail end plugs at the back of each head. I would clean everything as good as you can and see if you can see where the leak originates. Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 01-17-2007, 01:31 AM   #3 (permalink)
KRP
The oil from the turbo drains through the pedestal and back into the block and then goes to the pan. I'm not sure what you mean by where it goes into the pan? So you know there is also a '99 and up forum a little ways up from this one.
2000 F-250 Ex.Cab 4x4 Auto with Homemade Intake, 4" Exhaust, DP Tuner Chip, Tugger Kit, 2 HPOPs, ITP Fuel System/Boost Regulator, AC injectors, and Van Turbo/WW
KRP is offline
Old 01-17-2007, 11:46 AM   #4 (permalink)
Your replies are helpful. If can't fix the problem, will try the 99+ forum. Will post when the problem is fixed.
earld444 is offline
