Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 05-07-2008, 07:48 AM   #1 (permalink)
turn signals not working
the bulbs look ok when lights are on and the hazards work but the turn signals do not work. I know that sometimes when a bulb is out the turn signal will light up but not flash and this time it is not lighting up. Any suggestions?
billyjoejimbobjr is offline
Old 05-07-2008, 08:08 AM   #2 (permalink)
eagleeye's Avatar
Your multi-function switch is probably bad.
Travis
1996 Extended Cab Long Bed XLT, 4x4, 3.55LS, Tymar Intake, Diamond Eye Performance 4" Exhaust, Meyer C-8 Plow, Timbren Load Levelers
Case 1845c Uni-Loader
PowerStrokes And Duck Hunting-It Doesn't Get Any Better
eagleeye is offline
Old 05-07-2008, 08:47 AM   #3 (permalink)
Make sure that the hazard light button is up fully (in the off position). It can sometimes stick in the halfway position and prevent the turn signals from operating.
1996 F-350 PSD 4x4 DIY intake, STANCOR GPR
zman6665 is offline
Old 05-07-2008, 11:19 AM   #4 (permalink)
Send a message via AIM to 96P_Stroke4x4
check the turn signal flasher located in the dash fuse panel
Matt
'96 F-250 XLT,ext-cab,4x4,BTS E40D,249k,dana60,swamps175/173s,CPR Fuel sysatem installed 8/2/08,rear discs4" dp to 6" exhaust w/ twin 6" miter cut stacks,Tymar,Autometer Lunar Boost,Pyro,and Tranny Temp,white-faced gauges, intercooler,diamond headlights and corners,onboard air,HX mod,Twildman 6-position chip,shimmed fpr,led 3rd brake light,2 green neon underbody kits+extras,clear cab lights,alteeza tails,4 corner strobes,Sirius satellite,kenwood mp3 player
NRA Life Member
North-South Skirmish Association
"Gotta love the fresh smell of diesel and black powder in the morning!"
96P_Stroke4x4 is offline
Old 05-07-2008, 11:24 AM   #5 (permalink)
MarkEkberg's Avatar
My Photos: (13)
You have two flashers in the system. One is for the 4 ways and one is for the blinkers.
If that does not work look at your ignition. Sometimes it will remain too far forward to the crank position.
1996 F-250 extended cab long box five speed. Home made Tymar, 203 Stat, 60 gal in bed fuel cell, 315/75's, no cat, no muffler, ebpv welded open 3" to 3" DP, Babies. 255K, still chugging, and still smoking when cold.
MarkEkberg is offline
Old 05-08-2008, 09:32 AM   #6 (permalink)
crashmk92's Avatar
Ditto on the flashers. Replace both while you're in there. I spent 8 bucks and put a nice electronic flasher in the front, and a new thermal relay in the back (for the hazzards) while I was in there. I had the same problems until I replaced them. Good to go now.
1997 F250 HD 7.3L PSD E40D 4X4 ; 4" Superlift Suspension, ProComp ES9000 Shocks, Skyjacker Steering Stab.,Energy Suspension Poly Shackle Bushings, DIY Baldwin open element intake, 285/75 R16 AT Liberators,15w40 Rotella T, Valvoline Maxlife Mercron ATF, Power Services Diesel Kleen (cetane +6), Midland 77-120 CB w/ Firestik FL2 4' Antenna. 1900RPM @ 70MPH. 135,000 miles on stock powertrain.
Truck Birth-Month : October, 1997
New Additions: Graco "toddler" car seat (Because she loves riding in daddy's pickup truck!)
FUTURE ADD-ONS: Chrome wheels, Trans Temp Gauge (someday)
FC1, USN
TRUCK PICS
crashmk92 is offline
Old 05-08-2008, 09:57 PM   #7 (permalink)
1badpsd's Avatar
i would just check the fuse i think it is like #13 or 16 i changed mine yesterday
95' F-250 Powerstroke 4x4, Beans stage 1's,custom beans burned TS 4 position, afe stage 2, 3inch down pipe, muffler and kitty are hidin in the barn,
5 speed with south bend con fe 550hp, dipricol boost and pyro,modified IDM.
Coming Soon:
beans stage 3 hybrids
H2e
beans fuel system
and maybe some other stuff
1badpsd is offline
Old 05-13-2008, 12:16 PM   #8 (permalink)
Thanks guys, it turned out to be the other blinker fuse. I over looked it when I replaced the other one.
