water in fuel light - Diesel Forum - TheDieselStop.com
Old 06-26-2009, 08:33 AM   #1 (permalink)
water in fuel light
first let me say that it been awhile lot of changes to the site looks good
i have a 95 f350 four door dually first start truck things are ok drive get truck good and warm shut off go to restart the water in fuel stays on
check fuel no water check filter and under heater no water need help
thanks rick
1995 f350 cc dually 2wd coolant filters new water pump superchip straight exhast 3"down more to come
littlered is offline
Old 06-26-2009, 11:48 PM   #2 (permalink)
Rick,
I've been poking around trying to get more info on this system myself. There's a real informative thread over at FTE if you search on "water fuel warning light" in the Forums. Seems there's a ground lead in the filter housing that's triggered by the water level in the housing. If there's no water in the system, it's either shorting to ground to trigger the light or there's possibly a problem with the solid state switch built right into the wiring harness near the filter assembly. The thread will help a lot...
Mike
'97 F250HD XL 7.3 4x4 auto, D50 TTB, manual hubs, tow package, HD cooling, a/c 4.10s, stock, Curtis Sno-Pro 3000, 86,500 miles
msavoy is offline
