Water Pump question - Diesel Forum - TheDieselStop.com
Old 11-02-2009, 08:58 PM   #1 (permalink)
zombietroopers's Avatar
Water Pump question
So I just descovered that my water pump is wobbling slightly. It has about 125,000 km on it. It is not leaking and I will be replacing it this weekend, question is will it make it till then. Has anyone ever heard of the pump and clutch fan coming apart while driving? Should I be concerned. Any information would be appreciated.
1997 F-250 HD,5-Speed,4X4,Ext/cab,393,000 km 3" Turbo downpipe with 4" exhaust, No Cat,Firestone rear airbags,255/85/16 Toyo
M-55 tires,new transmission HD upgrade
Luk clutch/flywheel single mass conversion,Drawtight front hitch,Class 5 Hidden Hitch,Tekonsha brake controller,Warn 6000lbs.winch on custom removable plate,Tymar coolant filter kit,coolant eye,Tymar HPX kit,K/N cone air filter (open air),Shimmed FPR,SCMT 1705,Autometer boost gauge,Autometer pyrometer,SP Diesel EBPV dongle,Ford auxillary idle control.3 Electric cooling fans,gutted EBPV
zombietroopers is offline
Old 11-02-2009, 09:21 PM   #2 (permalink)
bugman's Avatar
My Photos: (18)
Do you have a quarter to toss into the air? Or to quote dirty Harry "Do you feel lucky." It may last the rest of the life of the truck or it may go when you start it up in the morning. Now if it was my luck I would of changed it as soon as I looked at it and saw a problem. But then I am the type of guy that could loose a bet in a one horse race.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 11-02-2009, 10:02 PM   #3 (permalink)
I agree with Bugman. Unless I had the money to replace the vehicle (or motor), I would not take a chance on melting it down.
95 F-250 4x4 supercab, E4OD, 3.55LS, TEE5, Rhino lined, Tymar Air Intake, Tymar HPX , Hypermax Downpipe, Isspro Pyro, Boost, Tranny Temp Gauges, Gutted EBPV,Shimmed fuel reg Rockin S Gauge Pod, 4" exhaust, Donaldson muffler, Bilstein shocks, SCMT off road setting, factory AIC, Ebay screen name gcduece
Ford Axle Codes
gcduece is offline
Old 11-02-2009, 10:32 PM   #4 (permalink)
Point taken, waterpump will be fixed right away.
Thanks again
Old 11-03-2009, 10:50 AM   #5 (permalink)
Zrock's Avatar
I just had my fan spin off and go through my rad over a stupid mistake
1995 F250 Powerstroke
Zrock is offline
