Old 04-21-2005, 08:30 PM   #1 (permalink)
Water Pump..What years interchange
Group
whatyear water pumps will fit a 97 PSD?
Also will a superduty one fit?? Also how about the 99-2003 years
are they interchangeable with the 97?
2001 Ford Excursion PSD
69crewcab is offline
Old 04-21-2005, 09:47 PM   #2 (permalink)
Re: Water Pump..What years interchange
I am not sure about a SD fitting a 97. I do know a 96-97 will work on a 95. So I imagine a 95 would work on a 97 also. There are a few differences, but they are minor. One is the heater hose fitting is difference. The 96-97 takes an O-ring where as the 95 is screw in. And the bottom of the pump is two pieces on the 96-97 where as the 95 is one piece. Maybe someone else can help you with the SD question.
[img]/ubbthreads/images/graemlins/phoney.gif[/img]
95 F250, 4X4, E4OD, 4.10, Hypermax DP and Tymar 4" Exhaust System, Tymar Air & Coolant Filters and HPX Kit, Tymar Fuel Fill mod, External Transmission Filter, Schaeffer's ATF. Add-a-leaf, Redline Differential gear oil and Redline ATF in Transfer Case. OilGuard By-pass oil filter. Amsoil 15W-40 engine oil. A-Pillar...Autometer Boost, Pyrometer and Trans. Temp. Gages, Under dash...Oil Pressure and Water Temperature gages, 1705 Superchip Tuner, Stancor GPR, Factory Tech Valve Body, 4739 Tru-Cool Transmission Cooler, Explorer Overhead Console, Diesel Turbo Lifesaver.
Griz is offline
Old 04-21-2005, 10:16 PM   #3 (permalink)
94-97 will interchange. The most important difference is the thermostat. A 96-97 thermostat will not fit in a 94-95, as it is about 3/4" longer. If you put a 94-95 thermostat in a 96-97 pump, it will fit, but will not block the bypass port. This can lead to overheating in parts of the engine even while the gauge reads normal!
If in doubt which pump you have, measure from where the thermostat seats to down inside where the bypass port is (Webshots PIC) . Approx 1.5" on 94-95, 2.3 inch on 96-97.
While expensive, you can also upgrade to the International Pump with an integral coolant filter. There are some threads with good descriptions of this, but until I can search the archives I can't get them for you. Maybe someone has a write-up [img]/ubbthreads/images/graemlins/shrug.gif[/img]
JOAT is offline
Old 04-22-2005, 08:05 AM   #4 (permalink)
69, if you go with the earlier waterpump you can go to the hotter and cheaper t-stat. Built a bushing for mine so i could run the 94 t-stat and really like it, also getting about 1.5 to 2 mpgs better. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
2002 3/4 ton 4x4 auto, edge juice and attitude, 4" magnaflow exhaust,97 4x4 CC 5sp. aftercooled, gutted,new valeo smfw clutch, no silencer, cleaned, , amsoil front to rear, Western diesel 4 page chip, 3 in. downpipe, 5 inch exhaust, boost and pyro guages, equalizer hose between the heads, WWJD on the sides. Also 86 F250 4x4 sc 5sp Hypermax turbo 3.5 exhaust, aftercooled,balanced, 640,000 miles
tupco is offline
Old 05-22-2005, 01:57 AM   #5 (permalink)
crumm's Avatar
My Photos: (38)
Anyone have a write-up on the IH pump swap? My pump started leaking today and I need to replace it. Hard to find much information with the archive search down..
Powerstrokeshop.com lists the 95-96 pump and list a different one for 97 and it is a little cheaper. I have the longer stat in my 1996 so I suppose if I go with a Ford pump I should order the 97' pump to get the right one?
1996 F-350, 4X4, XLT, C/C, 5sp, 4.10, Chip, DPPI Down Pipe, Tymar intake, Shackle reversal, 315 Toyo MT's, 67,000 miles.
crumm is offline
Old 05-22-2005, 04:48 AM   #6 (permalink)
AlH
Not necessarily, many 96/97 are one piece. This is not a reliable indicator of year. My 96 is one piece and so have been BOTH replacements, one a 95 and one a 96 I've bought.
Al
96 F350 CrewCab BTS-E4OD 4.10 4x4 / Banks Git-Kit / 99-Intercooler / 99 Tahoe 25TB ToyHauler / 00 FourWheelCamper Pop-up
AlH is offline
Old 05-22-2005, 07:56 AM   #7 (permalink)
Renegade's Avatar
My Photos: (28)
Send a message via ICQ to Renegade
Crumm,
though I dont know how to link to it - in the archives section I found one of my old post posts about the IH water pump.
It was called - manleyjt - - need a refresher on the water pump blues
#699910 - 04/06/02 09:40 AM
I think it covers about everything you should run across but it seems the final belt length with the IH or Ford idler pulley was different than listed on the post being in the 122 3/8" area & since that post I think there was another lower preformed radiator hose found that will work also.
Brian
95 F-250 XLT,SC,4x4,TDE1,LWB,4:56's,Dana 60,E4OD(lightly tuned),Tymared,Swamped,Lifted,rear disc brakes,6 pos chipped & a pile of other odd & end mods.Trucks,Parts & Misc. Pics 05 F250 V10 too
Renegade is offline
Old 05-22-2005, 09:31 AM   #8 (permalink)
Thanks Renegade, I've been looking for a link on that too.
HERE'S THE LINK
(If you want to copy a link from the archives, right click it in the search results page and "copy Shortcut")
JOAT is offline
Old 05-22-2005, 06:26 PM   #9 (permalink)
crumm's Avatar
My Photos: (38)
That should answer most of my questions if I decide to go with the IH waterpump. One question, does IH offer a 203* stat? I really like my 203* and don't want to go back. The heater output is much better with the 203*. The 203* I have will not fit the IH pump since it has the longer shaft.
crumm is offline
Old 05-23-2005, 08:20 AM   #10 (permalink)
Crumm,
I just did the swap on my 96 a couple of months ago. Here is a thread that has some links.
http://forums.thedieselstop.com/ubbt...amp;PHPSESSID=
If you have any questions I'd be happy to help you out. I also swapped out all of my hoses and put in a heater core bypass, a brass T instead of the plastic factory T, and added a temp gauge on the drivers side head as a backup for the factory gauge in the WP. Also have a source for the 1"NPT to 3/4" barb you need for the WP if you have a 96 or older engine.
BTW the IH setup is awesome IMHO. It makes testing SCA and adding SCA a breeze.
TP
'96 F-250 PStroke 4X4 E4OD
'74 Bronco 4X4 302/C-4
'03 Kawasaki KLR-650 2X1
KROWBAR26 is offline
Old 05-23-2005, 08:22 AM   #11 (permalink)
Crumm,
They offer a 185 and a 192. They MAY have a 203 I did not look that hard. I have the 192. My head coolant temp runs 194 deg all day long.
TP
Old 05-23-2005, 08:26 AM   #12 (permalink)
WARNING FOR IH PUMP REPLACEMENT
If anyone decides to do the swap. Measure your bolts to make sure they are the right length. The IH dealer gacve me 40mm instead of 30mm by mistake. Please trust me, measure your bolts.
TP
Old 05-23-2005, 08:31 AM   #13 (permalink)
Renegade's Avatar
My Photos: (28)
Crumm - if you choose the IH pump you wont need the hotter tstat as warmup time to the cab is greatly increased over the Ford pump [img]/ubbthreads/images/graemlins/wink.gif[/img]
Brian
Renegade is offline
Old 05-23-2005, 05:44 PM   #14 (permalink)
crumm's Avatar
My Photos: (38)
What makes the IH pump warm up faster? Is it moving more or less coolant?
crumm is offline
Old 05-23-2005, 08:20 PM   #15 (permalink)
Renegade's Avatar
My Photos: (28)
Really I dont know but it does put heat to the cab a lot faster & I havent had a bit of overheating issues at all.
My guess is that since its origin was in commercial trucks that work hard & use a big fan & radiator is that it flows a bit more. (Just a hunch though)
Brian
Renegade is offline
