Water Pump..What years interchange - Page 2 - Diesel Forum - TheDieselStop.com
Old 05-23-2005, 10:43 PM   #16 (permalink)
Re: Water Pump..What years interchange
Could be the location of the heater return fitting allows better coolant flow during warmup. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
JOAT is offline
Old 05-24-2005, 07:46 AM   #17 (permalink)
sea97stroker's Avatar
OK guys i have a oem style waterpump from IH that has the one piece bottom hose connecter, is this a 95 style pump? I put a 97 thermostat in the pump , do i have the wrong one in there? The 94-95 pump is the only one that has the one piece bottom hose connecter? I do seem to remember the pump from IH looked a little different than the one i took off.In the summer when pulling hard the temp gauge will head to the hot side a ways also.
Stevo
1997 F350 CC 5 Speed 4x4 , BDP Stage 2's, Wildman Chip, Isspro Gauges, 5 inch stacks, SD Turbo Setup,Banks Intercooler,Tymar Intake, SD Leather Seats. Dyno 427hp/813tq
sea97stroker is offline
Old 05-24-2005, 09:08 AM   #18 (permalink)
actually our 95 international rollback has a smaller radiator than my 97 ford. But, the 95 heats up really quick compared to the pick up.
1997 F350 CC 4x4 5spd- 4.10, XLT, custom intake, custom 4 inch exhaust, 4 inch lift, cerametallic clutch, Ramsey hydraulic winch, PTO, swamp babies, 6 pos. TS chip, hideaway strobes etc..all the goodies
1995 F350 Wrecker, 4wd, Vulcan 882
Truck Pics
Wreckaboy1 is offline
Old 05-24-2005, 12:46 PM   #19 (permalink)
The correct IH pump to use depends on the engine serial #. If you have the serial # then you can cross ref which pump to use in the IH catalog for the 444 engine.
I think the "cross over" was in mid-1995.
TP
'96 F-250 PStroke 4X4 E4OD
'74 Bronco 4X4 302/C-4
'03 Kawasaki KLR-650 2X1
KROWBAR26 is offline
Old 05-24-2005, 01:19 PM   #20 (permalink)
Stevo
97 thermostat would not fit a 95 pump (too long), so you're OK. Some aftermarket newer pumps have the cast inlet.
JOAT is offline
Old 05-24-2005, 10:26 PM   #21 (permalink)
Thanks Joat, some days i'm not the sharpest tool in the shed.
Stevo
