Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 10-30-2008, 03:11 AM   #1 (permalink)
u2slow's Avatar
My Photos: (20)
weird no-start
I thought a had a glow-plug relay problem, so I went over to full manual glow plug control with a momentary toggle switch. It pulls 150Amps so I know its working. But apparently that's not the problem. Its still tough to start
Now I thought my wait-to start light would be gone after that. Its not. It still does the same thing it always did independently of my new manual control. The weird thing is that while I'm cranking - sometimes the wait-to-start light comes back on kind of pitifully - and at the moment it will fire up. If the light doesn't come on, it just keeps on cranking.
I also don't hear any injector clicking while cranking.
Ideas?
(BTW: its my 97 E-series - but I figured this is more engine specific than van)
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s
, D60 swap, straight pipe, turned up fuel screw, 9.00R16 Michelin XS
Other Engines I mess with:
Mitsibishi S6U-MPTA
Mirrlees National KVSSM MK-II
DDC/MTU 12V2000
u2slow is offline
Old 10-30-2008, 03:49 AM   #2 (permalink)
PSDfreak's Avatar
hmmm...kind of sounds like your PCM is doing something funny...Looks like your 95 is a 5 speed but the PCM should at least start the motor in the van I would think...what about switching PCM from truck to van and see if it starts?
Just throwing out ideas
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio● ALLFF BRAH!
PSDfreak is offline
Old 10-30-2008, 06:17 AM   #3 (permalink)
ford_doctor's Avatar
This is likely the clue to your problem. If you don't hear the injectors clicking while the engine is cranking that tells me you may have an ICP concern. This could be an oil pressure build-up problem, ICP sensor, IPR valve... but your description of the wait to start light sounds odd.
Ford Master Diesel Technician
Diesel Technician Society
ford_doctor is offline
Old 11-01-2008, 04:25 PM   #4 (permalink)
If you have no injector clicking, then check the level of the HPOP first. The oil is what fires the injectors. To check the level, there is a pipe plug on top of it, just remove it and look in there. It should be within an inch of the top. That is where I would start. The dim wts is kinda weird though... Hope you figure it out and post the results so future ppl with same problem will find the answer.
2005 F250 LARIAT CC 4X4 6.0L PARROT CK3200 bluetooth car kit, Shaker 500 system, nice set of train horns, twin viair compressors and 5gal tank, 5" MBRP turbo back, AFE stage II intake, SCT tuner.
1996 F350 AT, IDM and switched ICP mod
1995 F250 SC AT, IDM and switched ICP mod, 6" susp 2" body lifts.
1994.5 F250 SC 5spd 4x4 IDM and ICP mod
bondsman is offline
Old 11-01-2008, 11:45 PM   #5 (permalink)
u2slow's Avatar
My Photos: (20)
I'm figuring that as soon as the injectors start up, the engine starts. It does make sense that the IDM could be looking for enough oil pressure.
For now, I can at least run my glowplugs before I even turn on the ignition. Then after I turn the key, I can start it during the few seconds the "wait to start" light is on.
I would be happy to wire in a bypass for the IDM so it ignores whatever its looking for.
Mitsibishi S6U-MPTA
DDC/MTU 12V2000
u2slow is offline
