What rear axle do I have?? - Diesel Forum - TheDieselStop.com
Old 07-05-2009, 10:57 PM   #1 (permalink)
kolo's Avatar
97 crew cab, srw 4X4 auto with factory limited slip. Do I have a sterling or Dana 70 in the rear? How do I tell?
1993 F450 Superduty 2 whl drive,7.3 IDI, E4OD auto, non Turbo, reg. cab flat bed, mostly stock I believe.
1997 F350 crew cab 4x4, PSD, open air intake, 3"down pipe,MBRP, sonnax valve in auto, gutted EBPV, 130,000 miles, 4.10 limited slip,fifth whl. hitch, now Dually with 96 Axle, International water pump w/coolant filter, 57 gals. w Bronco rear/ 24 plastic front, electric fan on tranny cooler.
kolo is offline
Old 07-05-2009, 11:10 PM   #2 (permalink)
96P_Stroke4x4's Avatar
Send a message via AIM to 96P_Stroke4x4
sterling 10.25 is what the 94-97 f-250s and f-350s have. i forget what the f-superduty has.
Matt
'96 F-250 XLT,x-cab,4x4,BTS E40D,301k,dana60,Swamps175/173s,Dieselsite Adrenaline HPOP,CPR Fuel system,rear discs,4" dp to 6" exhaust w/ twin 6" stacks,Tymar,Autometer Lunar Boost,Pyro,and Tranny Temp,white-faced gauges, intercooler,diamond headlights and corners,onboard air,HX mod,Twildman 6-position chip
NRA Life Member
North-South Skirmish Association
"Gotta love the fresh smell of diesel and black powder in the morning!"
2012 VW Passat TDI
96P_Stroke4x4 is offline
Old 07-06-2009, 12:35 AM   #3 (permalink)
Jinco's Avatar
Try this What is my Ford rear end ratio, do I have positraction - Drivetrain.com
Buy Ford. They're not taking bail-out money.
2000 F250 XLT PSD Crewcab, Longbed, 4x4, Auto, LS 3.73
Ford AIS, Frantz Bypass Oil Filter, Baldwin Bypass Coolant Filter, Fumoto Drain Valve, 203* Thermostat, Stancor
Bilstein Shocks all the way around, Timbren SES (Rear), Bridgestone Dueler Revo A/T 265/75/16
Commander Monitor (gauges), Crimestopper CS-2016 DP II FM Remote Start/Alarm/Paging/Turbo Timer/Keyless
Rotella 5W40 Oil
, Texaco ELC Coolant, Mobile 1 ATF Trans and PS
My mods, repairs, and other truck Stuff
Jinco is offline
