What Size Is Fuel Pump Banjo Bolt - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 05-26-2006, 09:30 AM Thread Starter
My Photos: (9)
I need to get around to fixing my fuel pump someday, I guess I need a box end wrench for that banjo bolt there. It is a 49 state 97 model truck. I am going to do it with the turbocharger left on.
Birken
Birken Vogt is offline
post #2 of 9 (permalink) Old 05-26-2006, 10:22 AM
BlueMule's Avatar
My Photos: (12)
Re: What Size Is Fuel Pump Banjo Bolt
1" [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Rodney#33
BlueMule is offline
post #3 of 9 (permalink) Old 05-26-2006, 09:30 PM
blw3 took a box end wrench and put a bend on it to clear the turbo pedistol. he said it was a serious pain. the wrench helped. just an idea for you when you are trying to turn that banjo and the pedistol is in the way.
<span style="color: #000099"> 96 F-250 CREWCAB POWERSTROKE... Stage 1 injectors... 6 position Tony Wildman chip: stock, economy, daily, tow, hot tow, & Luke Cline Extreme... Superduty IDM mod... Tymar intake... Tymar 3"X4" down pipe... Tymar 4" exhaust... Tymar high pressure oil crossover... 6.0 intercooler-PIPES thanks to GTS... CCV mod... V10 transmission cooler... 203* thermostat... shimmed FPR... gutted EBPV... Monster Box trans... 4.10s... Dana 60 front... LS rear w/ extra qt and a half diff cover... three gauge pod full of Autometer's... AIC... Turbo pedestal mod by Rick96F250 and a 3/8inch shorter bolt on the rear passenger side of the pedestal... Nippondenso starter... THINGS TO DO: get a big turbo, big oil, and big fuel... RSK with SD springs.</span>
<span style="color: #CC0000"> #26</span>
krowell is offline
post #4 of 9 (permalink) Old 05-26-2006, 10:53 PM Thread Starter
My Photos: (9)
Just did it with no great effort required any different than any modern car...I mean it is a royal PITA but what isn't these days. I broke it loose and did the final tighten with the box end but used the open end to spin it out and yes I did have to flip the open end over and over to get two different bites on each flat, all the way out 1/12 of a turn at a time. But I am used to that. I reused the old seal washers since they stuck in place on the banjo and that made it easy to put the bolt back in. Otherwise I would have used some tacky gasket sealant or something. Also the pump did not want to lift out of its bore but after breaking it loose with big pliers and lifting it somewhat, I bumped the starter with the conveniently located fender solenoid and a big screwdriver until the pump popped up a little further but it did not appear that the plunger really wanted to fall out anyway.
Birken
post #5 of 9 (permalink) Old 05-27-2006, 12:21 AM
Birken
i wish i would of done that when i did mine. man what a pain. [img]/ubbthreads/images/graemlins/sick.gif[/img]
RYAN
GAUGES, INTAKE, EXHUAST, SBC CLUTCH, CHIP, BDP INJECTORS, BILSTEINS, BUSHINGS...AND A WHOLE LOT MORE..
B99 BIO DIESEL SUPPORTING AMERICAS FARMERS.
US NAVY
looking for an ext cab 4x4 short bed DURAMAX!!! keeping the obs of course.
1997PSD4ME is offline
post #6 of 9 (permalink) Old 05-27-2006, 10:31 AM
DeiselDaddio's Avatar
i used a 1 1/4" box end wrench and a 14 year old neighbor kid, without his small hands i couldn't have done it. he screwed it the rest of the way out and started it and screwed it in as far as he could in, then i wrenched it tight. hope this helps kirk [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Terminator HPOP,Custom Inter cooler install by Rockin "S" Performance, Full Force Stage 1's, Banks Down Pipe, "Authentic" Tymar Filter, Tymar 4" Exhaust, F.P.R.Shim,Pac-Brake,Autometer Z Series Pyro, Trans Temp, and Boost,DIY Coolant Filter,Amsoil, A Pillar Mnt,DIY Bypass Oil Filter,Tru-Cool Max Tranny Cooler, TS 6 Position Chip, Valve Body By Cale at BTS
DeiselDaddio is offline
post #7 of 9 (permalink) Old 05-28-2006, 12:52 AM
Happeetxn's Avatar
I used a socket with swivels and extensions to get it off and on, then tightened it with a box end.
Craig
95 F-350 PSD CC SRW 340,000 miles, daily driver, no note, Open air element, Bilstein shocks, open exhaust from turbo back, and happy with it as I can be
Happeetxn is offline
post #8 of 9 (permalink) Old 05-28-2006, 04:24 AM
What's a banjo bolt and who cares?
Retire36 is offline
post #9 of 9 (permalink) Old 05-28-2006, 06:07 AM
It's the bolt that holds your fuel lines to the fuel pump.If your pump quits you will be the one that cares.
97 F-250 PSD 4wd 5spd 4.10 SCLB, D60, Tymar intake, 3"dp, EBPV gut, Boost/Pyro gauges, SBC Con-O, Stancor 586-902 GPR, Royal Purple gear and tranny oils,225k
96 F-350 PSD 4 door dually auto 2wd all stock,112k
'87 Tbird TC Auto
'87 Tbird TC 5sp
clem is offline
