where is the evaporator coils located at? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 04-14-2006, 10:39 PM Thread Starter
where are the evaporater coils located at i think mine might be plugged and need to be cleaned, any pics???
thanks guys
95 F250 PSD-auto, ext cab, 2wd, k&n drop in, faubiam motorsports trans.
02 F350 PSD-4dr, 4X4, drw, auto, line-x, sirus sat. radio, single position TWildman Chip, Napa 6637 Open Air Element, de-clawed, sonnax and tricumulator, ebpv delete, faubian motorsports trans.
pawsranch3 is offline
post #2 of 6 (permalink) Old 04-14-2006, 11:09 PM
Patrick Feeley's Avatar
My Photos: (19)
Re: where is the evaporator coils located at?
In the box on the lower firewall, passenger side. You'll have to remove the silver heat shielding and some other small stuff to remove the cover. There is one screw that you access from inside the cab (at least on mine). Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #3 of 6 (permalink) Old 04-14-2006, 11:16 PM
They're inside the plastic cover that protrudes forward from the passenger side firewall, just outboard of the passenger side valve cover.
You may have to pull some of the silver insulation off to see it.
You can sort of see in there at the evaporator by removing the heater blower motor (3 screws, passenger side inner fender, close to firewall), then using a flashlight and a mirror.
I removed my blower motor and flushed it off with a water hose.
It was caked with dirt, and grime! Here's a shot of what one guys looked like when he pulled his blower motor:
Evaporator Coil
The water will drain out of the bottom of the housing onto the ground.
Good Luck! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
1997 F250HD Regular Cab 4x4, 4.10 SRW, Handshaker ZF5 Tranny, Bean Stage I's, TWildman 4 Pos Chip, 3" Downpipe/4" Exhaust, Tymar Intake, Luk Single Mass Flywheel/Clutch, IDM Mod, Ford AIC, Stancor GPR, HX Mod, Gutted EBPV, Dead Kitty, Coolant Filter, 203* Stat, Twin Electric Fans, A/C Mod, GPR Bypass System, 1.0 A/R Turbo Exhaust Housing
There's no Substitute for Cubic Inches!!!
F250Jockey is offline
post #4 of 6 (permalink) Old 04-15-2006, 05:44 AM
Gag! He must have lived on a dirt road or worked construction.
[img]/ubbthreads/images/graemlins/eek.gif[/img]
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed. CD Changer
Velvet rides installed. Joe Servo IDM mod was installed. Replaced with Swamps HV/HF IDM! Rear air lift springs. 4" exhaust installed all the back from DP and bye bye Kitty.
Sparkydm is offline
post #5 of 6 (permalink) Old 04-15-2006, 08:09 AM
or--following other people tooo close on a gravel road--with the air on--around here--seen it once toooo often--
94_turbo is offline
post #6 of 6 (permalink) Old 04-15-2006, 09:39 AM
That'll do it!
Sparkydm is offline
