why do the front wheels toe out when you back up on the 250's - Diesel Forum - TheDieselStop.com
Old 07-05-2007, 02:26 AM   #1 (permalink)
PSDan000's Avatar
My Photos: (11)
Send a message via AIM to PSDan000
i really only noticed this after i put my lift on, but ive been told its normal. whenever i back my truck up the front wheels will toe out really bad like this / \ but once i pull forward again they straighten right back up, what is the cause of this? thanks
-Dan
1997 F-350 PSD, Cali Truck, 165k, 4x4, Reg Cab, LB, 4.10's, Auto, Sandpiper Diesel Performance 4" Exhaust, DIY Open Intake, Autometer Gauges, TS 6 pos Chip...more to come.
#24
PSDan000 is offline
Old 07-05-2007, 03:36 AM   #2 (permalink)
Re: why do the front wheels toe out when you back up on the 250's
IFS
96 f350 4x4 zf6 speed with a ceramic clutch and np271, 4 door srw. tymar style intake,3.5"dp,5"exhaust into 5" exhaust, custom swamp 6 pos chip,185cc swamp injectors,sperco intercooler with hypermax intake y and bb turbo ,exhaust brake, diy electric fuel system, 17* oil pump, high pressure x over and gauge,10k mod,map sensor mod,gauges,20"x12 m/t classic II wheels with m/t 35x13.50x20 baja atz, 4.10 gears.pioneer head unit,sony amp, rockford subs,goose neck hitch, think thats about it so far.
dummy099 is offline
Old 07-05-2007, 10:25 AM   #3 (permalink)
bugman's Avatar
My Photos: (18)
It is intersting that some on here have that kind of problem. I back my truck up 150' every time that I park it in my diveway at home and have never noticed it.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 07-05-2007, 01:19 PM   #4 (permalink)
96P_Stroke4x4's Avatar
Send a message via AIM to 96P_Stroke4x4
i had the same problem on mine, even after changing all the bushings (spring and pivot), and the ball joints. never figured out what was causing it. i completely solved the problem with a dana 60
Matt
'96 F-250 XLT,x-cab,4x4,BTS E40D,301k,dana60,Swamps175/173s,Dieselsite Adrenaline HPOP,CPR Fuel system,rear discs,4" dp to 6" exhaust w/ twin 6" stacks,Tymar,Autometer Lunar Boost,Pyro,and Tranny Temp,white-faced gauges, intercooler,diamond headlights and corners,onboard air,HX mod,Twildman 6-position chip
NRA Life Member
North-South Skirmish Association
"Gotta love the fresh smell of diesel and black powder in the morning!"
2012 VW Passat TDI
96P_Stroke4x4 is offline
Old 07-05-2007, 02:46 PM   #5 (permalink)
Invader1's Avatar
This is normal on the D50 TTB. It is not a problem. They will straighten back out when you go forward.
Make sure your alignment guy knows this. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Invader
97 F250 XLT SuperCab LB E4OD
Mod's: Tony Wildman 4 page chip, Stealth HPOP, Beans fuel system, JoeServo high voltage IDM, Swamps 175/173 injectors, Hypermax H2E turbo and inter-cooler, open element air filter, Down pipe, open exhaust, exiting in front of rear wheel, with dynomax bullet race muffler. Home made, dual stage, Propane system, ATS TripleLoc billet steel Torque converter. Imperial Shift Kit, BD PressureLok. Mag-Hytec tranny pan and rear cover, ARB air locker in the rear. Cervinis Fiberglass ram air hood ,(part # 112). 4" Superlift lift kit, Air lift air bags with Smart air auto leveling system in the rear, Full instrumentation, Grant steering wheel, on board air system. Putco skins stainless bed rail/tailgate covers. Stainless Nerf bars. Billet front grill and clear lenses all the way around.
My Truck Pic's
Invader1 is offline
Old 07-05-2007, 03:39 PM   #6 (permalink)
It's because as you back up with the slight toe in that is supposed to be there it tries to pull the tires outward and from this force is also pulls the suspension down causing the toe to change even more. It seems as though I recall it giving more toe in though but I haven't payed attention to it for awhile.
speediesel is offline
