Will these wheels fit? - Diesel Forum - TheDieselStop.com
Old 02-14-2013, 10:13 AM   #1 (permalink)
Just trying to make sure these wheels will fit on my truck. Here is the link 20x9 Polished Alloy ion Style 171 Wheels 8x6 5 0 Dodge RAM 2500 RAM 3500 | eBay It says they will here but I know the hub on the OBS fords are bigger than chevy and dodge. Says the hub bore of the rims are 130.81mm. I couldn't find the hub size for an OBS. My truck is 97 F350 CCLB 4x4.
1997 F350 CCLB 5 Speed, 3" Down 4" back, DP Tuner, 6" Lift, 10k mod, 37" Tires, AFE Intake, Custom Bumpers, Gooseneck Hitch, South Bend clutch
olson72189 is offline   Reply With Quote
Old 02-14-2013, 01:19 PM   #2 (permalink)
chevy and dodge both have auto locking vacuum accuated hubs that dont protrude out thru the rim. for an 8x6.5 lug wheel yes it will fit a 90's model ford D60 hub.
Dwayne93 is offline   Reply With Quote
Old 02-14-2013, 07:47 PM   #3 (permalink)
The actual hubs on the Chevy and Dodge aren't vacuum actuated. They are unit bearing hubs and don't lock/unlock. Dodge has a vacuum actuating axleshaft disconnect. I believe that the Chevy half-shafts turn all the time and the only disconnect is at the transfer case.
You need around 4-5/8" to clear the OBS hub and those are a bit over 5".
Snowtow is offline   Reply With Quote
Old 02-14-2013, 10:47 PM   #4 (permalink)
Okay thanks guys!
