wont start - Diesel Forum - TheDieselStop.com
Old 07-08-2009, 08:13 AM   #1 (permalink)
wont start
97 powerstroke turns over sounds like timing no compression history truck quit running put in new cam sensor no go new transferpump no go but turned over strong let sit for 2weeks tried to turn over nothing just click replaced starter still just click put in 2 new batteries still just click put on charger started to turn over but sounds like timing put on scan comes back as high pressure pump could this cause the motor to turn over like this
trcooll is offline
Old 07-08-2009, 12:39 PM   #2 (permalink)
Have you checked the oil level in the HPOP? If not it should be within an 1" of the inspection hole.
Griz
02 F250, 4X4, 4R100, 3.73, Amsoil Air Filter, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug and Intercooler boots, 6.0 Transmission Cooler.
Griz is offline
Old 07-08-2009, 01:45 PM   #3 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
Its probably not timing, psd's are timed by gear, and ive never heard of one jumping its time. First, you need to make sure its turning over fast enough to even start. Check your battery cables and connections. Charge it up until you get 14 volts across the terminals on the batteries. Then try starting it with the charger still on. Sounds like the batteries are still low in it. Just because theyre new doesnt mean they are charged. These trucks need AT LEAST 10.5 volts and 100rpm cranking to even consider starting.
1997 F-350, XLT, dually, crew cab, 4x4, 7.3 PSD, zf-5 speed, Autometer Pyro and boost, DpTuner F5, 3.5"DP , B+W turnover goosneck hitch, 2wd to dana 60 swap
http://community.webshots.com/user/91diesel
18.9MPG
91diesel is offline
Old 07-08-2009, 01:49 PM   #4 (permalink)
Griz
the oil level is in range
trcooll is offline
Old 07-08-2009, 01:52 PM   #5 (permalink)
my biggest worry is the engine turning over like there is no compression
trcooll is offline
Old 07-08-2009, 03:01 PM   #6 (permalink)
bugman's Avatar
My Photos: (18)
You need to start at the basics. Are all the fuses under the hood good? The major ones are number 22 and number 9. Are you getting any smoke out of the tail pipe? Also do you have any fuel in the filter housing?
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 07-08-2009, 03:25 PM   #7 (permalink)
fuses all good no smoke fuel bowl is full
trcooll is offline
Old 07-08-2009, 08:57 PM   #8 (permalink)
bugman's Avatar
My Photos: (18)
Is the HPOP draining out to where you have to refill it? No smoke means that the injectors are possibly not firring or the there is a problem with the HPOP system. On other possibility is that you have no fuel pressure to the injectors. You can check the fuel pressure on the drivers side of the filter housing. There is a scrader valve that you can put a air pressure guage on and check. I believe that you should have at least 50psi.
Jim
bugman is offline
Old 07-09-2009, 03:13 PM   #9 (permalink)
Jim
the hpop resevior will actually overflow when i take the screw out after turning over engine. seems to have good fuel pressure have had 3 mechanics look at it first opinion the motor is shot second guy didnt know third mechanic said the hpop isnt working only 240psi played with it got it up to 450psi need 500psi min. he wants to replace hpop but doesnt know if it will work. i would feel better about it if someone could tell me if a bad hpop would make the engine turn over like ther is no compression
trcooll is offline
