Won't start every time - Diesel Forum - TheDieselStop.com
Old 10-05-2012, 10:11 PM   #1 (permalink)
95DRW4x4's Avatar
Not sure whatís up. Truck wonít start every time! Turns over but won't start. Some times it wonít start when I first try and will start on later attempts. Sometimes itíll start right up and then wonít start later. Sometimes it starts every time. It eventually starts, usually after a 5 to 10 minute wait. Distance driven doesnít seem to matter because I can drive 5 to 155 miles with same problem. Just started doing this three to four months ago. This truck is not a daily driver but is usually driven at least once every two weeks. I bought new CPS and put on with no change. Fuel pressure is 60 psi and HPOP pressure is 2000 psi at start according to gauges. I've noticed very small amounts of smoke at exhaust when it doesn't start. Once it starts it runs and pulls fine. Got modified IDM about one month ago, but problem pre-existed this mod.
95 F350, 7.3 PSD, CC, ZF5 speed, 4x4, Dually, Autometer EGT, Boost and Engine Temp Gauges, HPOP and Fuel Pressure Gauges, DP and 4 inch exhaust, Tymar Intake, CPR Fuel System, Adrenaline HPOP, Intercooled, IDM Mod
85 Ranger, 302, ZF5 speed, Klune-V, Dana 20, Explorer front and rear diffs, 35 inch TSLs, ARBs, Superwinch
95DRW4x4 is offline   Reply With Quote Quick reply to this message
Old 10-07-2012, 10:09 PM   #2 (permalink)
95DRW4x4's Avatar
Happened again this weekend. No start on first try Saturday and easy start this morning. Anyone with an idea?
Old 10-07-2012, 10:51 PM   #3 (permalink)
My first guess would be batteries.
444-4D is offline   Reply With Quote Quick reply to this message
Old 10-08-2012, 11:33 PM   #4 (permalink)
95DRW4x4's Avatar
Thanks, I'll start there. I've got a plug in volt meter and I'll record the volt readings the next few times I'm in the truck to see what kind of readings I'm getting.
Old 11-19-2012, 10:19 PM   #5 (permalink)
95DRW4x4's Avatar
444-4D You are right on the money. I bought two new batteries three weeks ago and its started every time since. I guess that little more power making the turnover faster makes a difference. Thanks 444-4D
Ľ Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
