ZF tranny problem - Diesel Forum - TheDieselStop.com
Old 09-03-2008, 10:20 PM   #1 (permalink)
My Photos: (6)
ZF tranny problem
Was trying to change out the trans fluid in the 5-speed, and couldnt get the filler plug out. Ended up stripping it, and had to tear it up with a chisel to get it free and back it out. Dont know why the heck it was in so dam tight, the drain was so tight had to use an impact to get it out. ANYWAY, where the heck do I get a new filler plug? It is a straight thread with a flange that seals to the tranny. Dorman make replacements or it this a friggin dealer thing? Any help appreciated. I Tig welded a nut to it, and tried to fix the torn up flange so I can at least drive the truck, but its leaking already.
**97 F250HD Supercab, PSD, 5-spd., 4.10, long bed, fpr mod.,HPX mod, 203 stat, Diamond Eye 4" exhaust, AFE intake and Scorpion switch chip.
**03 F150 Crew, Harley Edition, blower motor, chipped, exhaust, intake, lowered 3, fast
**01 Fatboy, 95" motor, cam, exhaust, ported/polished, rolls out!
**07 Screaming Eagle Dyna, all the goodies, 110" motor, torque monster, wheels up third gear
mohead1 is offline
Old 09-03-2008, 11:13 PM   #2 (permalink)
johndeerebones's Avatar
Grease a pipe tap up real goo and tap it out and put a pipe lug in it. The reason they stick so bad is that the dissimilar metals becomes a corrosion point. They can be a real pain to get out as you have seen. Another way is to get the drain out like you did and fill it through the shifter. capacity is 3.8 qts I think. Most people claim better operation with a rounded off 4 qts. You have to fill through the shifter for that.
Sold, back when the snow was on...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 09-05-2008, 12:10 AM   #3 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
From the stuff I have (not that its that helpful):
ZF# 0501 209 879, Screw Plug M22 x 1.75, Ford# F81Z 7A010 AA
ZF# 0636 304 049, Screw Plug M24 x 1.5, Ford# E7TZ 7A010 C
ZF# 0636 304 150, Screw Plug M24 X 1.5, Can't cross it to a Ford number
Don't know which one it actually is, but you can probably figure it out. Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 09-05-2008, 07:33 AM   #4 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Probably a dealer bolt. I would guess it will be a 10 dollar bill.
I agree the drain is a pain. I always end up with a 6' cheater so I can be out from under the truck and stand to loosen it.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 09-05-2008, 10:20 AM   #5 (permalink)
My Photos: (6)
Thumbs up Plug Sizes
Hey Patrick,
Thanks bud, thats exactly what I was looking for. I am not a big metric measurement fan, but can get it close I imagine. So M22 is the millimeter diameter and the 1.5 is length?? Is that right? Looking at plugs on the Dorman web page, I think I remember a similar sized plug on there. May just crap out and go to the "stealer" and order one. But thanks much for the info, that helps.
mohead1 is offline
Old 09-05-2008, 08:15 PM   #6 (permalink)
My Photos: (19)
M22 or M24 is the millimeter diameter and the 1.75 or 1.5 is the thread pitch (millimeters per thread). Cheers!
