On my 94 F-350 PSD I have the 5 spd. ZF tranny. I had problems getting it into reverse. Some times it would feel like it was in & when I let the clutch out it would grind. I got used to it though. I have only had the truck a little over a month now. I bought it as a project. I was goona let it go the way it was now, but I got a bright idea to put a snowplow on it. So yesterday I took the tranny out & tore it aprt. I have a book & followed the instructions. I can't seem to see anything wrong with it. Can anyone tell me what to look for. I thought it was the synchros but they look Ok.
Also, what does a dual mass flywheel look like. I unbolted the clutch to see what it looked like & it looks like some recently replaced the clutch & flywheel. Thanks
The dual mass flywheel will look close to the same as a solid one from the front. Feel/look behind it, there are springs that cushion the two plates..it is pretty obvious if they are there or not.
1997 F-350, XLT, dually, crew cab, 4x4, 7.3 PSD, zf-5 speed, Autometer Pyro and boost, DpTuner F5, 3.5"DP , B+W turnover goosneck hitch, 2wd to dana 60 swap
Your shifting issue is likely from worn nylon bushings in the pedal assembly area.
I already checked the bushing & it is good. It is definitely internal. I packed it up in a box last night & it is going to the local transmission shop today. They said it is a common thing with the ZF tranny & 90% of the time it is the 5th-reverse synchronizing cluster. They are gonna take a look at it to make sure on this one & put it back together for me.
My ZF has been doing that for 4 years and I plow snow with it. I'm so tired of it but from what I understand you might just as well overhaul the whole thing if your going to fix the synchro's. Let me know what you find out. RB
94 PSD 4x4 ZF cab/chassy converted to an extended cab flatbed. Hood scoop off a 79 Mustang/Hypermax down pipe/open air filter/Homemade goose neck, 1" AR housing, SMF, NP205 transfer case. Worst truck I've ever owned-But somehow I love it! God bless! RB
Someone must have changed my flywheel. I took a look at it today & there are no springs.
The transmission shop called me on Fri. The 5th-Reverse synchros were bad. Also the reverse gear was bad from grinding it so much. They should have it together for me tomorrow. Its gonna cost around $625.
Thats about 1/2 what my shop wants. RB
