ZF5 PTO - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 03-20-2017, 11:23 AM Thread Starter
ZF5 PTO
im going to replace my zf5 s47 with a 42 because I can't find a 47. I have a 96 f super duty. People are telling me that the pto will match up , but one shop that rebuilds the transmissions said that it won't and I will need a different pto . Anyone know . Thanks
Also the one guy said he got his transmission from a 2000 7.3 . Will that fit in a 96
alltow215 is offline
post #2 of 3 (permalink) Old 03-20-2017, 12:32 PM
klhansen's Avatar
My Photos: (180)
I believe that most PTOs have standardized mountings, but the input gear may change, so I can't say for sure that yours will swap over. You should be able to check it out on a PTO manufacturer's site. Here's Chelsea's applications page:Welcome
A manual tranny from a 2000 7.3L would be a ZF-S6-650 (6 speed rated for 650 ft-lb of torque). It will bolt to the back of your earlier 7.3L (may need a specific spacer plate), but you may have issues with the shift tower location and/or clearance to the cab floor. It's significantly larger than the ZF5.
), AIS,
regulated return,
klhansen is offline
post #3 of 3 (permalink) Old 03-20-2017, 04:55 PM
79jasper's Avatar
Iirc, 42 vs 47 have different specs for pto.
You may have to swap the drive gear in your pto.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
