Re: 10.25" disc brake kit for a dually?
You might try to locate a E-350 dually van as they use the Dana axle with the inch bolt pattern that fits the OBS rims. Newer than 96, I think and 2000 for sure as my 2000 dually work van has the dually/rear disc combo. The van axle spring mounting location may be narrower than the F- truck axles though.
Dave Murakami 97 F-250 XLT Supercab PSD OffRoad, Bilsteins, Warn manuals, Rhinoliner, Bridgestone 285's, molded steps, smittybilt grille guard w/frame braces, Cibie driving lights, power rear window, Sony CD changer w/infinitys+basslink subwoofer, Tekonsha Prodigy, Snugtop, Reunel stainless steel rear bumper w/Warn HS9500 winch/PIAA backup lights, TFI, 7500lbs, 14.508 1/4, 408 rwhp/#2only, banks powerpack, gutted ebpv, 4" duals, map pressure regulator, JSidm, BTS, maddog stage II ABs, Bean's fuel system, Terminator, dieselpower tri-chip, tymared, black intake, non-fluttering Isspro EVs, almost stock!
