I have been getting A CEL at higher rpms I checked and have a 1211 code
I have AD Injectors and a 17 deg pump I set it even on the 1st chip setting. any ideas??
thanks
97 F-250HD Super Cab 4X4
Jasper E4OD, 3.55 gears
Auto Meter Dash Mounted: Trans temp, Boost, EGT, Oil Temp, Oil Pressure.Water temp. Gauges. http://photos.thedieselstop.com/show...t=1&thecat=500
Homemade Open Air Filter, 3 in SS DP, SD, 03 Intercooler. GTS kit. Modified Pedestal, ITP SS HX, CCV Mod, BABY SWAMPS & SWAMPS 6 POS Chip, 17 Deg HPOP, Gutted EPBV, Jasper Stage 1
249,000 Miles, and still going Strong.
TSM Disk Rear Brakes
below desired Continuous and KOER on-demand test IPR valve failed, stuck, or shorted to ground
1996 F-350 psd crew duellie,declawed, demuffed,fumotoed, home-made intake, edge evo, post triple pillar auto meter gauges,line-x (10-16-05).Seat mod (11-13-05).on-board air(viair 450c) with horns (Kleinn triple train) (8-21-06).Bilsteins (11-28-06)Upgraded headlight harness.IDM MOD by Matty, SOCAPS member <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />thanks Matt!! more mods to come.
I would replace teh IPR jsut to be sure, other than that your running out of oil volume, and can not hold desired pressure.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
only at about 26-28+ lb of boost is it because of the AD's needing more oil than say AA stage 1's? As soon as i get time and a good weekend I have stage 1's AA's going in should that clear it up ?
