Old 03-06-2006, 01:38 AM   #1 (permalink)
1994.5 - 97 PCM difference?
SO whats the difference between the 94.5-97 PCM's.
I have a stock PCM on my 94.5. IS there a better PCM version out there and does anyone know the specific differences?
1994.5 F350CC XLT 4x4 5sp
3" DP, TS chip, Tymar intake,HPX mod, coolant filter, Gauges,gutted cat,bilstien shocks
Gmanak is offline
Old 03-06-2006, 05:36 AM   #2 (permalink)
Re: 1994.5 - 97 PCM difference?
Only difference is the programming in the pcm. The upgrade would be to a newer version. I know the preferred one for auto's is TDE1, not sure about hand-shakers though. First you need to know your PCM code. Ford routinely upgraded the PCM as trucks came in with problems that could be fixed with a flash.
Art
2005 Dodge Durango Limited w/HEMI.
2006 Chevrolet Cobalt LT.
agsF2501 is offline
Old 03-06-2006, 09:27 AM   #3 (permalink)
so we can just have our trucks reflashed to that code
91 F-350 rollback car hauler, 7.3, 5spd, 159,000 miles, stock,stock,stock/SOLD,SOLD,SOLD
96 F-250 ex-cab swb,powerstroke,tymar,stock"for now"sold sold
05 F-250 sold
03 F-350 single wheel, 4wd, stock, 258,000 miles!!sold
06 F-350 4 door,4wd,tow command,tow boss,lariat,everything you could get sold
00 excursion diesel 4wd limited sold
02 E-350 Traveler powerstroke sold
bbmotor is offline
Old 03-06-2006, 12:20 PM   #4 (permalink)
My Photos: (21)
Yes you can. Jody or the dealer can re-flash your PCM, or you can just have a chip burned to the better PCM code. i.e. you can have a 95 auto you can have a 97 TDE1 4 page, 6 possition chip burned so your 95 will have the power and shifting parameters of the 97's.
Since Snowgo has a 94.5 that means it's a 5 speed because if I remember right they did not make a 94.5 auto, only a 5 speed was available on the first PSD's.
JIM
His: 1997 F350 PSD, CC, 4X4, 4.10's, 35/12.5/16.5's BFG's
Hers: 1997 F250 PSD, X-Cab, 4x4, 4.10's, 315's
All My Photos
Toys/Blown Head Gasket
Drag Videos
motor/turbo/fuelsystem pics
Traction Bars
Father & Son Time
THE_ALASKAN is offline
Old 03-06-2006, 01:25 PM   #5 (permalink)
PSDfreak's Avatar
Also...with the older trucks (94.5-95) that are OBD I....having your PCM reflashed to a later calibration (96-97) you can then use OBD II diagnostic equipment...
-Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 03-06-2006, 04:10 PM   #6 (permalink)
TDE1 is I believe the latest and greatest. Though made for an auto, you can run it without issue in a 5spd (I am).
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
ryanPSD is offline
Old 03-06-2006, 07:57 PM   #7 (permalink)
Ryan, how much difference between TDE1 and MLE1 if you know? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Bud
1997(12/97) F250 SC XLT PSD 4x4 150k 4.10LS,5spd, 1998 BMW 323i conv, 1987 Mercedes 300D Turbo 175k, Mods include:Luk SM flywheel kit, Hypermax downpipe, no kitten, gutted ebpv, shimmed regulator, Donaldson open element air filter, add-a-leaf front.
BadTrukRisin is offline
Old 03-07-2006, 12:07 AM   #8 (permalink)
Dunno, I went from AUG6 with no chip to TDE1 with a chip... so I can't really say much about the differences between the two, except that it works. [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
- Ryan
285HP
ryanPSD is offline
Old 03-07-2006, 06:08 AM   #9 (permalink)
Thanks for all the info guys.
Im not sure what I have in the truck. I guess i would have to pull it out to check it. It does have the port under the dash. WOuld a code reader tell you the version when plugged in?
SO, if its still original PCM whats the best one to upgrade to?
I have the 5sp ZF42.
Gmanak is offline
Old 03-07-2006, 07:54 AM   #10 (permalink)
Your code should be BEG6 or BEG8 if its the original pcm. You should'nt need to upgrade your pcm. It looks like in your sig that you have a ts chip. Most chips will give you the most current pcm settings. befroe I got my chip, I played with a few PCM's in my truck and could'nt see any difference in any different pcm's. With a auto its a different story with different shifting patterns.
1994 F-250 PSD ext cab 5spd 4x4 Gutted ebpv ,Valeo smf and clutch,3 pos Tony Wildman chip!, 3-4" Dp, 4" exhaust,Tymar intake, shimmed fpr, HPX crossover, 1.0 A/R exhaust housing, vdo gauges, 279,000k
http://community.webshots.com/album/549770704UdvVUs
1996 F-250 PSD CC SB 4x4, 5spd, 4:10's SMF clutch, 3" dp, gauges, 6oh intercooler(GTS Kit), Tymar intake, HPX, .84a/r housing, 203* stat, 4pos Wildman chip!
ltfox is offline
Old 03-07-2006, 04:48 PM   #11 (permalink)
94 PSD, That I did not know. SInce I put this engine in i havent had any trouble or need to read codes. Just poor mileage due to warm up idling, #1 fuel and hubs locked in all the time.
ITs running good but I just cant quit fiddling with it.
Gmanak is offline
Old 03-07-2006, 07:34 PM   #12 (permalink)
so, who is this jody person? my tranny shifts funky. dealer reflashed it, shifted great. shut it off, started it later. and now it shifts like crap again. any help?
gw66 is offline
