A friend of mine has a 1994 F350 4x4 with a 3.73 rear end and is looking to improve performance. He has a K&N filter and is planning on installing a 4" exhaust. What kind of chip and other upgrades would you guys suggest. Thanks, Ed B
I use a western diesel chip and its great. Also getting rid of the cat. Depending on what he uses the truck for transmission cooler. Also if he wants to monitor his trucks preformance get a exhaust temp gauge, boost gauge and tranny temp gauge.
Check out This thread going on right now. There are alot of different options. As for exhaust, I went with Dale Isley at Tymar Performance, he does alot of different chips as well as guages, etc. The best is a straight pipe, but if he is going to use a cat/muffler at least get rid of the stocker downpipe and get a turbo back exhaust.
The best exhaust is what your prefer whether with a muffler or not. The most important upgrade is a new downpipe then an exhaust system.
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Ok, so to make it the easiest to get the exhaust from the turbo to the exhaust tip would be a straight pipe, thats what I meant, go easy on me [img]/ubbthreads/images/graemlins/cool.gif[/img]
Did he regear it? 3.55 or 4.10 unless its been changed, 3.73 came with the SD trucks.
Like said the downpipe should be trump over anything else, even he plans to keep it stock.
Next should be some other form of air intake. The stock box is known for its dirt sucking abilities. I made my own with a K and N, I would not recommend it, Call Dale at Tymar and get the good setup, cotton filters don't work well with our massive air needs, paper filters better and it is a sharp setup. Besides that I really didn't save enough money to make my homespun worth the money saved.
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
