Hey all. My 95 International 4700 T444E (7.3L) will not start. It has new glow plugs, relay is working, and I had it plugged in all night inside, so the motor is good and hot.
It fired up this morning, started to knock like it wasnt quite firing on all cyls, then slowly died out. Now its barely smoking, and sometimes it gives me a bang or studder.... With some smoke, but not much.
I just bought a new International work truck with the DT466, and was on my way to trade this truck in. DOH!
Any help with this would be wonderful. I know the 99-03 Powerstrokes really well, but not so much the 94-early99s.
I know its not a Ford, but its virtually the same motor, and I figured I would pick your brains a bit before I have it towed.
Thanks!
Sent from my Verizon 4G-LTE smart phone using Autoguide
Personal Trucks:
Red 2003 F250 XLT Crew Cab 6.0L Powerstroke FX4 162,000miles,
BONE STOCK
Black 2003 Excursion Limited 6.0L Powerstroke 178,000miles.
4" Magnaflow Turbo Back, Warn Manual Locking Hubs
It could be fuel related. I'm not sure if the International engine uses the same type of IDM to fire the injectors that the Powerstroke does or not but that could be part of the problem.
You may need to see if you can find a scanner that would work on the truck to check for codes and to see what is happening.
